3963512 two bolt BB - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 8th, 07, 07:59 PM Thread Starter
frank
3963512 two bolt BB
Does anybody know what year GM started making the 454 3963512 2 bolt main blocks?
wot
frankk is offline
post #2 of 4 (permalink) Old Feb 9th, 07, 02:47 AM
Re: 3963512 two bolt BB
GM started using the 512 block in 69 (both 2 and 4 bolt) for it's 427s. They started building 454s in 1970, so I assume your answer would be 1970.
buenymayor is offline
post #3 of 4 (permalink) Old Feb 9th, 07, 11:17 AM
Vintage 68's Avatar
Thumbs up Re: 3963512 two bolt BB
'512 Blocks started showing up @ Oct. of 1968 used in 427's and had a tall distributor casting boss in the rear of the lifter galley until @ Nov. 1969.
The 454 was released for production in fall of 1969, just before the casting was changed, so check to see if you have a tall (casting date will be on side of block) or short (casting date will be on rear bellhousing flange) distributor boss.
1968 Convertible
Some trucks
Vintage 68 is offline
post #4 of 4 (permalink) Old Feb 9th, 07, 09:58 PM Thread Starter
frank
Thanks, yes the casting # is on the side of the block. Frank
wot
frankk is offline
12 bolt swap in 1967 Camaro jrt67ss350 Brakes, Suspension & Steering 5 May 3rd, 07 08:38 PM
Door adjustment jsouthco68camaro Body Shop 9 Mar 7th, 05 06:46 AM
1968 door alignment Steve W Body Shop 5 Sep 9th, 03 05:15 PM
12 bolt swap......wrong rear end Damon Colson Brakes, Suspension & Steering 14 Mar 19th, 02 01:22 AM
Hanging Doors ? wesley58_do Body Shop 6 Jan 30th, 02 12:23 PM
