Valve clearence - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 9th, 07, 05:09 AM Thread Starter
Valve clearence
What is the correct valve cleareance settings for intake and exhaust on a 69 DZ 302?
DZ 3 0 Duece is offline
post #2 of 3 (permalink) Old Feb 9th, 07, 06:03 AM
Re: Valve clearence
Lash is .030.
TC # 349
zdld17 is offline
post #3 of 3 (permalink) Old Feb 9th, 07, 06:24 AM
Banned
Rob
satz28's Avatar
Re: Valve clearence
Originally Posted by zdld17 View Post
Lash is .030.
That would be the hot lash setting.
Here is a CRG research report by JohnZ that will allow you to set up the valve lash while cold. I've used it and it works great!
http://www.camaros.org/302valves.shtml
satz28 is offline
Need Help with valve adjustment on Small Block jsabowabo Engine 18 Jan 13th, 07 09:12 PM
PCV Valve KFH Camaro Tech 8 Oct 2nd, 06 05:32 PM
Are splash shields on valve springs helpful? JeffD Engine 11 Apr 6th, 06 02:43 AM
Which valve to use Sixty-Seven rs Brakes, Suspension & Steering 2 Aug 21st, 03 06:51 PM
383 piston to valve clearence Bcooper13 Performance 8 Mar 3rd, 00 05:04 AM
