Buying carb - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 9th, 07, 07:11 AM Thread Starter
Buying carb
Anyone know where i can order a new, good quality quadrajet. If not, any reccomendations on 4 barrel carbs for a 350.
MrCow350 is offline
post #2 of 7 (permalink) Old Feb 9th, 07, 07:17 AM
Re: Buying carb
Call up Sean Murphy Inductions, http://www.smicarburetor.com/
Sean will custom build you a STAGE 2 Quadrajet specific to your engine/exhaust/intake/driving habit. Cost is only $350!!!
I have an SMI carb on my 69 Camaro and one on my 63 Nova, I would never look anywhere else, these carbs are amazing and perform flawlessly
http://69camaro.nextmill.net/photos/smicarb
http://63nova.nextmill.net/pics/engi.../327Engine.JPG
Sean use to be a head guru at JET PERFORMANCE in Huntington Beach, he broke off I think 5 or so years back and started his own custom carb building business down the street.
Brian Lewis
and
Brian Lewis is offline
post #3 of 7 (permalink) Old Feb 9th, 07, 07:35 AM Thread Starter
Re: Buying carb
hey thx. Iv'e decided i want a quadrajet, unless im told otherwise because i dont much about cars. Whats the difference between stage 1 and 2?
MrCow350 is offline
post #4 of 7 (permalink) Old Feb 9th, 07, 08:02 AM
Re: Buying carb
$25 and a few things
Stage one Rochester Quadrajet
Rochester Quadrajet 4BBL 750cfm Stage one
Calibrated for stock, unmodified 1973 thru 1980 small block Chevrolet applications.
Select highest quality cores for best performance and reliability
Strip to bare metal, inspect for defects, then apply dyechromate coating for brilliant gold finish.
Strip and cadium plate all hardware, including throttle shafts, linkage , levers,spring and screws.
Surface baseplate for flatness and glassbead for bright silver finish.
Install APT (ADUSTABLE PART THROTTLE) to allow adjustment of part throttle and cruise speed (steady throttle, 1800-400 rpm) air/fuel mixture in seconds without any disassembly, tuning can be done while engine is running!
Apply epoxy to main body casting plugto eliminate common "leak down" problem associated with Quadrajets.
Install bushings in baseplate to eliminate any potential vacuum leaks at primary throttle shaft.
Assembly using highest quality components, including:
New jets and metering rods.
High flow .130 needle and seat assembly.
Nitrophyl solid composite float that can't crack ans sink.
Premium quality gaskets
High capacity accelerator pump featuring materials that are resistant to alcohol and other additive commonly found in today's fuel
New electric choke for cold staring and drivability.
New choke pull-off for clean,smooth warm-ups.
1 YR warranty all parts and labor
Stage 2
Stage two Rochester Quadrajet
Rochester quadrajet 750cfm stage two
Intended for moderately modified street performance vehicles.
All curcuits will be modified and tuned to match the specifications of your engine combination, Including:
Idle down tube(idle jet) and idle air bled resized for smooth idle quality with performance camshafts.
CRO(channel restriction orifice) resized for crisp off-idle and part throttle response.
Main jet and metering rods selected for clean cruise mixture and strong part throttle response and acceleration.
Proper metering rod power piston spring selected to match engine vacuum characteristics
Secondary metering rods and hanger selected and high speed air bleds resized for maxium full throttle horsepower and torque.
Idle, transition, main, and high speed circuits modified to provided optimum fuel curve for YOUR engine
Be sure to call up Sean and talk to him on the phone, he'll get you all dialed in for a carb that will work flawless for your exact engine. I recommend the Stage 2, thats what I have used from the get go. I am sure you can figure it out above or Sean can give you the details on that. Also let him know you were referred by some at Team Camaro, he has a big following at Team Chevelle (Tons of guys over there have used his carbs) and the more he hears about Team Camaro/Chevelle the more likely he is to sponsor this site someday.
and
post #5 of 7 (permalink) Old Feb 9th, 07, 09:04 AM Thread Starter
Re: Buying carb
ok, will do. Thanks a lot. By the way, i need to get some new headers soon, any kind you reccomend perhaps? I dont know much about headers, i jut want a lot more performance out of my engine and what not.
MrCow350 is offline
post #6 of 7 (permalink) Old Feb 9th, 07, 09:19 AM
Re: Buying carb
Thats a pretty subjective topic, I run the 65003 Hedman Headers, they are a full length header and fit pretty good with the Power Steering and KickOut Pan, they are designed for the first generation camaro. I believe its 66003 for the Ceramic Coated ones. Be aware that changing headers will usually result in needing to reweld where the exhaust bolts to the headers, they don't all connect up at the exact same point, some shorties will dump close to the block, some like the Hedman 65003 are much longer and dump out near the torque converter.
and
post #7 of 7 (permalink) Old Feb 9th, 07, 07:38 PM
Re: Buying carb
cow, did you ever get the thing to run right???last i heard, it was poppin and fartin...
kustomwerker is offline
Carb help on a 85 GMC Jimmy Fullsize 4x4 Jason1968Camaro Bench Racing 11 Dec 28th, 06 01:37 PM
Need some ID and value help on intake and carb GonHuntin Tag Team 5 May 26th, 05 06:27 PM
Carb adjustment question? supv26 Engine 14 Apr 23rd, 05 04:42 PM
2-bbl vs 4-bbl carb test onovakind67 Performance 8 Apr 17th, 05 06:02 PM
Edelbrock Carb performance help MrDanB Performance 4 Apr 7th, 05 07:27 PM
