When to change Shell rotella oil after break in?? Cam break in that is...... - Team Camaro Tech
post #1 of 10 (permalink) Old Feb 11th, 07, 10:21 AM Thread Starter
Do you change after the 20 min break in or should a guy drive it for a hundred or so miles????
Once a cam is broken in and the oil is changed, is it now okay to run straight syn oil???
Thanks!
dubs68camaro is offline
post #2 of 10 (permalink) Old Feb 11th, 07, 10:24 AM
Harry
dawg's Avatar
Re: When to change Shell rotella oil after break in??
change the shell after 20 mins with new shell rotella.
then after 500 miles go with synthetic
434 stroker
US Navy retired
dawg is offline
post #3 of 10 (permalink) Old Feb 11th, 07, 10:39 AM Thread Starter
Holy crap......it will take forever to get 500 miles on this thing!!!! Thanks!
post #4 of 10 (permalink) Old Feb 11th, 07, 10:42 AM
Russ
dawg is on the money,you need to let those rings seat before going to syn.
Russ
1969 RS conv,hugger orange,396 4 speed,373 12 bolt posi.
19694speed is offline
post #5 of 10 (permalink) Old Feb 11th, 07, 01:55 PM Thread Starter
Ooooops.....It's a cam break in.......not a motor!!!!
post #6 of 10 (permalink) Old Feb 11th, 07, 02:16 PM
Russ
Oh sorry,go with the syn on your next oil change then
Russ
post #7 of 10 (permalink) Old Feb 11th, 07, 03:30 PM
Harry
dawg's Avatar
Re: When to change Shell rotella oil after break in?? Cam break in that is......
still a good idea to do 500 miles !
because the lobes and cam will seat properly.
yes even synthetic wont help
434 stroker
US Navy retired
dawg is offline
post #8 of 10 (permalink) Old Feb 11th, 07, 03:58 PM
Why do guys like synthetic so much? What's wrong with 20W50 Racing oil? I recall back in the 1990's synthetic was not even SAE approved (it was missing the SAE stamp on the back of the bottle) So why do you guys like synthetic so much?
1) 1969 Camaro RS 396 TH 400, 12 bolt 3:73 sold 1994
2) 1984 Z28, 5.0 H.O. T-Tops, G92 3:73, sold 1994
3) 1988 5.7L IROC-Z, sold 1994
4) 1969 Camaro bought 2006, back on the road in 2010
post #9 of 10 (permalink) Old Feb 11th, 07, 04:20 PM
Harry
dawg's Avatar
once and engine is broken in synthetic oil flows better and last longer.
also its not prone to thermal breakdown like reg. oil is.
thus the engine last longer and tolerances will be maintained longer .
434 stroker
US Navy retired
dawg is offline
post #10 of 10 (permalink) Old Feb 11th, 07, 04:53 PM
How about cam lobe wear and synthetic oil? As far as I know no one has said anything about it. I use Rotella as regular oil but you must change it just like any other non synthetic.
oger is offline
Let's talk about motor oil, zinc and cams... DjD Camaro Tech 47 Sep 11th, 06 07:45 PM
Milky oil....Help! Gary68SS396 Engine 5 Sep 20th, 05 12:51 PM
Use reg oil or Amsoil 2000 to break in rearend DenRS Transmission & Driveline 4 Jun 20th, 05 07:41 PM
1967 327 Oil pan Gasket change? 67jicho Engine 4 Apr 4th, 05 08:31 PM
Engine Break In....When do you change the oil garfield Engine 6 Mar 25th, 05 07:17 AM
