Which heads for my 305 - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 11th, 07, 06:40 PM Thread Starter
Patrick
I'm building a cheap 305. I have several early castings and some late model centerbolt ones. Which ones should I use to get the most power from this junk? It is going in a truck.
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
post #2 of 5 (permalink) Old Feb 11th, 07, 09:19 PM
T
Re: Which heads for my 305
Pretty soon, PDQ67 will chime in and tell you how the -601 heads are great little heads for small motors....
From what I've read, -601 heads from an early 305 HO are probably the best, followed closely by the -416 heads. Both should be 1.84" int, 1.5" exh valve heads with tight combustion chambers and pretty good flow. Both are also early (perimeter bolt) heads. The --601's have a bit better combustion chamber (and also smaller), but the 416's should be good as well. There's also a similar style centerbolt head (i.e. 305 HO centerbolt, similar to the 416) but I can't seem to find the casting info -- I think they're the 081 castings, but not sure.
Various threads of note:
http://www.chevelles.com/forums/showthread.php?t=95090
http://www.thirdgen.org/techboard/tb...-headflow.html
http://www.thirdgen.org/techboard/te...6-airflow.html
TMessick is offline
post #3 of 5 (permalink) Old Feb 11th, 07, 09:58 PM
T said it well!!
-601 heads are dandies on the smaller engines, imho!!
In fact, I have a set...
pdq67
post #4 of 5 (permalink) Old Feb 13th, 07, 07:08 AM Thread Starter
Patrick
Thanks guys, I'll look through my stuff and see if I have any. again thanks
383 IS SOLD!
Building a 489BBC
post #5 of 5 (permalink) Old Feb 13th, 07, 08:04 PM
Chad
From my experience, the 081 castings (centerbolt) are cleaner and better cast than the 416s. Haven't played with 601s...(are they the Vortec version for 305s?). L98 aluminum heads work well on a 305, too.
Do spend some time at least bowl blending them...makes a big difference.
69 Camaro X55 4speed
9.08 @78 in 1/8th...stock with headers and exhaust
Don't wait for conditions to be perfect to begin. Beginning makes the conditions perfect.
Big Box Monkey is offline
Heads, i need to choose. Ryan's 64 Engine 9 Sep 9th, 06 03:02 PM
305 heads on 350 question buzz61 Engine 5 Jul 6th, 06 08:45 PM
406 needs new heads jackr Performance 9 Jun 7th, 06 11:34 PM
Pro Action Heads my69gofast Performance 25 Feb 22nd, 03 08:33 AM
truck heads vs. hump heads toolman Tech 2000 3 Nov 1st, 00 09:34 PM
