Power steering and water pump/alternator belts for 69 Big block - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 11th, 07, 09:16 PM Thread Starter
I'm looking for a Gates or equivalent part number for belts for my 69. I have a long water pump and stock pulleys (single on water pump, alt, and PS pump, double on crank). I do not have the AIR pump or A/C.
The ones the Autozone lookup spit out are too long, and not because it is supposed to have AIR. I know I can try to figure how much shorter I need and go back and have them look for one, but I figured I'd check to see if anyone knows replacement belt numbers that fit well.
TIA!
Eric
Eric Kammerer is offline
post #2 of 5 (permalink) Old Feb 12th, 07, 05:15 AM
Re: Power steering and water pump/alternator belts for 69 Big block
www.rockauto.com
lists: WP & alt:
GATES Part # 7460 {High Capacity V-Belt (Standard) HC41 3/8" x 46 5/8"}
Fan & Alt.
post #3 of 5 (permalink) Old Feb 12th, 07, 08:34 AM Thread Starter
Thanks Ev, I had that look up. I guess I can get a fleixble tape and try measuring to confirm this would work, but I was hoping someone will have numbers from belts they actually put on their car.
Eric
post #4 of 5 (permalink) Old Feb 12th, 07, 12:45 PM
take an old junk belt that's too long and cut it down until it fits. then take that to the parts store and get that one and maybe one or 2 that are shorter. once you find one that fits, take the others back. if you get a cool counter guy, they might not make you pay anything until you find the proper belt. places like NAPA might be cooler about this than places like Autozone...
yes, it's a pain..
you don't plan sincerity.
novaderrik is offline
post #5 of 5 (permalink) Old Feb 12th, 07, 04:30 PM
Bob
Get a Dayco Top Cog p/n 1546011A1170 092 B:3
Available at Advanced Auto, spins over 6K with no problem. These are the numbers that I just read off of my belt. I'm guessing that something there is the part number.
Bob
Garnet Red 69/SS396/TH400/355 Posi Sold
'02 triple blk Vette Vert. now
94 HD Dyna Wideglide
phel69 is offline
67 Camaro Power steering gear box pdq67 Brakes, Suspension & Steering 5 Nov 8th, 14 09:14 AM
Power Steering Bracket to Water Pump?? Andrew69 Brakes, Suspension & Steering 2 Oct 2nd, 05 06:29 PM
trouble adding power steering to my 67 RS DPeter2101 Brakes, Suspension & Steering 6 Apr 6th, 04 09:06 PM
Power Steering / Belt Alignment Problem kgaffney Tech 2000 17 Jul 9th, 01 05:36 PM
Power steering in a Big Block Draayer Tech 2000 4 Jul 7th, 00 08:06 AM
