click or anyone that knows amsoil - Team Camaro Tech
post #1 of 24 (permalink) Old Feb 12th, 07, 06:19 AM Thread Starter
Rick
Does amsoil make a 14" x 3" or 4" air filter? I'm thinking about switching from my K&N setup. Could go paper but, hey, why!
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings! SOLD
67 Belair with perfect floors, pinchwelds and firewall. Hmmm!
RickD is offline
post #2 of 24 (permalink) Old Feb 12th, 07, 07:54 AM
click's Avatar
Re: click or anyone that knows amsoil
I have to dig up my dimension catalog, back at ya later what is the KN number it might cross reference for me. 14 x 3 or 14 x 4 but what about across the filter area? 1.5" ? or 2"? or how thick is the filter media area across the top of the filter?
click is offline
post #3 of 24 (permalink) Old Feb 12th, 07, 10:34 AM Thread Starter
Rick
What, now you want me to be technical
I'll check.
Rick Dorion
RickD is offline
post #4 of 24 (permalink) Old Feb 12th, 07, 10:40 AM Thread Starter
Rick
E-3031r
Rick Dorion
RickD is offline
post #5 of 24 (permalink) Old Feb 12th, 07, 10:57 AM
click's Avatar
wouldnt you know its not in the cross ref. list, Ive emailed tech support for the info. back later with it
click is offline
post #6 of 24 (permalink) Old Feb 12th, 07, 11:30 AM
click's Avatar
that number doesnt cross reference to anything, are you sure of the number and its a K&N number ? they can help too with the additional measurement across the top of the filter media.
click is offline
post #7 of 24 (permalink) Old Feb 12th, 07, 11:49 AM
DjD
DjD's Avatar
K&N E-3745 is a 14 x 3.5 element if that helps...
...Dennis
DjD is offline
post #8 of 24 (permalink) Old Feb 12th, 07, 01:15 PM
click's Avatar
thanks Dennis but they couldnt cross that one either, maybe not a current K&N or something odd, I need that other measurement of the thickness of the filter, then they said they can find the right match by size.
click is offline
post #9 of 24 (permalink) Old Feb 12th, 07, 01:46 PM Thread Starter
Rick
I'll measure tonight. I took the number off the K&N website.
Rick Dorion
RickD is offline
post #10 of 24 (permalink) Old Feb 13th, 07, 05:27 AM Thread Starter
Rick
My K&N is 14" across, the sealing surface is 7/8" inch across making the inside diameter 12 1/4". The top/base have a 1" wide space for the filter to sit into so there's a little wiggle room. Thanks, Jim.
Rick Dorion
RickD is offline
post #11 of 24 (permalink) Old Feb 13th, 07, 12:21 PM
click's Avatar
Okey dokey they crossed it to a Model Eaa25 measures 4.056 high by 13.875 O.D. and 11.625 I.D. suggested retail is $38.10 BUT that is a 2.2" thick filter... is that too thick for your space in the notch? I emailed the Tech guru again and asked for him to check one more time on another filter with 1" max width of filter area.
click is offline
post #12 of 24 (permalink) Old Feb 13th, 07, 12:45 PM Thread Starter
Rick
I'll recheck to see if there's any room to wiggle. Is there a 4" tall model avail or 3.5"? 2.2" won't clear the carb. Seems there would be a market since they're popular sizes for sbc's Thanks, Jim.
Rick Dorion
RickD is offline
post #13 of 24 (permalink) Old Feb 13th, 07, 01:11 PM
click's Avatar
The 2.2" is the 'thickness' of the filter area, (not height of the filter) the 2.2" is inbetween the O.D. and I.D. measurement.. not height (tallness) of the filter..
yes there is a 3.04" "tall" filter the Eaa52 with same O.D. and I.D . but thats still 2.2" thick in your slot as well.
We need to find an O.D. of 13.875 and I.D. of 12.875 to keep our filter width at 1" right??
click is offline
post #14 of 24 (permalink) Old Feb 13th, 07, 01:38 PM
Christropher
Click, this was directed at you because both you and Amsoil are both old.
Christropher
...in pieces still.
clwilcox33 is offline
post #15 of 24 (permalink) Old Feb 13th, 07, 02:08 PM
click's Avatar
thanks I just ran and pulled a few gray hairs out
click is offline
Starter..Click....Click freebird Electrical & Wiring 3 Aug 8th, 06 09:38 PM
Amsoil manual transmission lube lowrida Transmission & Driveline 25 Feb 13th, 06 08:41 PM
Click, click with motor... Indpowr Engine 1 Nov 15th, 05 07:11 PM
Car won't start... click click DRJDVM Camaro Tech 12 Oct 10th, 05 07:05 PM
Use reg oil or Amsoil 2000 to break in rearend DenRS Transmission & Driveline 4 Jun 20th, 05 07:41 PM
