rusty block,heads,crank - Team Camaro Tech
post #1 of 10 (permalink) Old Feb 12th, 07, 08:45 AM Thread Starter
How much rust is too much rust befor machining cant be done? Block, crank and heads I think have never been cut.
gregvega is offline
post #2 of 10 (permalink) Old Feb 12th, 07, 08:54 AM
Re: rusty block,heads,crank
I'm glad you wrote this because I'm in the same situation. I had someone give me a 402 that is lightly covered with surface rust all over. It will be interesting to see the replies. I'm just guessing that it depends on whether it's surface rust or pitted. I think the lifter bores are really the only thing. Boring will take care of the cylinders. The jounals really only hold the bearings in place. I think it gets back to pitting vs surface rust that can be removed. As for the crank and heads.....that's another thing.
dubs68camaro is offline
post #3 of 10 (permalink) Old Feb 12th, 07, 09:24 AM
Somebody has posted before and after pic's of a block that was rusted really bad.
It cleaned up fine using the shake & bake and then blast method.
It might be either Carl or Mike over on Team Chevelle, sorry, I forget????
pdq67
post #4 of 10 (permalink) Old Feb 12th, 07, 09:48 AM Thread Starter
Whats the shake and bake method?
gregvega is offline
post #5 of 10 (permalink) Old Feb 12th, 07, 11:12 AM
Great question....that's how I do my chicken, so I'm curious what this procedure is.
post #6 of 10 (permalink) Old Feb 12th, 07, 11:55 AM
They bake a dirty block in a big 500/600 degree oven for several hours to burn all the crap off it, then media blast it and then tumble it, (I think), to remove all the blasting media.
Then deck, line-bore or hone, etc., etc., and it comes out looking almost like NEW!!
Much nicer looking than using the old, out of EPA's favor, the caustic hot-tank method that has always been done in the past..
pdq67
post #7 of 10 (permalink) Old Feb 12th, 07, 05:12 PM
Dan
If you can, take some photos of the block, crank and heads to a local machine shop and get their opinion. You may just want to take the crank and heads if the engine is disassembled since they're not that hard to move around. Just a suggestion.
Carbo is offline
post #8 of 10 (permalink) Old Feb 12th, 07, 05:42 PM
Gary
Shake and bake, bubba. Shake and bake.
Goes together like cocaine and waffles.
Anybody else get a kick out of the NASCAR parody, Talladega Nights?
Gary Adrian
FCS Harmony Racing
Momma always told me not to look into the eyes of the sun.
"But momma, that's where the fun is!"
Busted Knuckles is offline
post #9 of 10 (permalink) Old Feb 12th, 07, 05:54 PM
Chad
67 Plum's Avatar
Best movie ever made.
67 Plum is offline
post #10 of 10 (permalink) Old Feb 13th, 07, 08:17 AM
It all depends on how deep the pits are and if it's been machines previously.
go2fast is offline
Rusty Car or Solid Original Panel Car Wayne Bench Racing 18 Sep 20th, 06 01:26 AM
Replacing rusty floors, trunk etc. on 69 convertible 69ndpce Body Shop 4 Jun 5th, 06 02:58 AM
rusty bondo quarters!! curtis26 Body Shop 2 Feb 11th, 06 07:51 AM
Rusty Bolts / Hardware Resto Pro Street Garry Restoration Corner 18 Nov 16th, 05 09:43 PM
Rusty headers Paint? bil1024 Engine 27 Apr 26th, 05 05:38 PM
