What numbers to look for? - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 12th, 07, 12:33 PM Thread Starter
Jan
I'm about to go look at a 327 engine for my ragtop. According to the seller, the engine is put together using a block from 1967. How can I tell the block was made back in 67 (or 66, for that matter)? Between what numbers should it be?
Are there any typical "327 flaws" or anything else I should look for or "are they all the same"
As my Camaro was originally equipped with a 327, I am very keen to get hold of it but want to make sure I'm not taken for a ride. The guy runs a legitimate business so I doubt he'll try anything funny..
Short info from the seller: 327 block, balanced steel crank, 10.25 comp pistons, all new bearings, 480/480 cam original inlet manifold. Can't remember what carb he put on it. He will dyno test it when I get there and everything seems to be in order.
To this one - I will add Flowtech Afterburner headers with aFlowmaster American Thunder 2.5" system
Sounds like a good combo?
67 Swedish Convertible
67 Swedish Convertible is offline
post #2 of 7 (permalink) Old Feb 12th, 07, 01:24 PM
Vintage 68's Avatar
Re: What numbers to look for?
Check the Casting Number & Date and the Suffix code on the front pad for the information you'll need.
Here is the CRG number location information - http://camaros.org/numbers.shtml#EngineNumbers
Here is a link to "NastyZ28"'s site for quick reference to the Suffix and Casting information - http://www.nastyz28.com/sbchevy/sblock.html
Just read through this information and make a list of the numbers you may need to reference ( like a couple casting numbers for the year[s] your looking at ) or recourd the info and check it when you get home.
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 7 (permalink) Old Feb 12th, 07, 01:29 PM
67 block casting numbers will be 3892657 or 3903352. The engine assembly code will end in MA, MB (327/210HP manual transmission), ME, MF (327/210HP manual transmission), MK, ML (327/275HP manual transmissions), MM, MN (327/275HP with power glide transmission).
If your car was assembled in the Antwerp plant the engine code will be stamped on the Antwerp tag atached to the firewall. If it a US assembled car the engine should be dated within about a month (usually less) prior to the cars assembly date noted on the cowl tag. The assembly date is stamped on the pad located on the passenger side top front of the block just below the head, and will end with one of the two letter codes noted above. The engine casting date is typically a few days to a week prior to that date and is on the passenger side top rear face of the block. It will be in a format consisting of a letter, followed by two or three digits. The letter is the month of the casting, A for January, B for February, etc. The next 1 or two digits is the day the block was cast, and the final digit is the year the block was cast.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #4 of 7 (permalink) Old Feb 12th, 07, 03:44 PM
Sixty-seven and earlier have an oil filter cannister, a replaceable filter element verses 68 and newer with a replacable oil filter, i.e., screw-on oil filter.
I think 66 and earlier have a "road draft tube" coming from an extra hole in the block next to the distributor. Sixty-seven is PCV valve, or closed crankcase ventilation.
post #5 of 7 (permalink) Old Feb 12th, 07, 03:56 PM
Jeff
My 67 327/210 MT has a # V0627MA and it has canister filter and a road draft tube
kart11 is offline
post #6 of 7 (permalink) Old Feb 13th, 07, 01:51 AM Thread Starter
Jan
Thanks alot for that! I'll try and get all numbers etc off of the seller. Don't be surprised if I show again asking you all to help decode numbers..
post #7 of 7 (permalink) Old Feb 13th, 07, 11:22 AM
Vintage 68's Avatar
Wink Re: What numbers to look for?
That's why we're here is it
Oh, btw - you won't find a "draft tube" on a 67 block .
"Draft Tubes" were illegal after 1962 ...
You will find the pre-67 rear block crankcase vent provision.
EITHER -
A cup adapter assembly, for the rear vent hole, ran to a hose that had a PCV valve in it, that mounted to an adapter/elbow that was mounted to the base of the carb at the intake - this was used on standard 49 states vehicles.*
OR -
On RPO-K24 equiped vehicles, a hose ran from the air cleaner to the rear tube assembly at the vent opening - this was used on CA emission and High Altitude vehicles. **
Do a search for 'PCV' or 'Draft Tube' - I think you''ll find it discussed lots of times ...
notes:
* = in this system the air flow was - from the Breather Cap on the oil fill tube, through the block crancase and then out the rear vent opening adapter through the PCV to the base of the carb/manifold. (air flow was 'out' ... )
** = in this sytem the air flow is - from the air cleaner base, through the adapter to the block crankcase and then out throught the PCV valve, mounted in the oil fill tube, to the base of the carb/manifold. (air flow is 'in' ...)
1968 Convertible
Some trucks
427 numbers 67-427 Tag Team 2 Jan 12th, 09 07:27 PM
Engine Component Numbers ET Tag Team 5 Feb 2nd, 06 12:18 PM
No Block I.d. Numbers - 427 Copo???? Help gonewacky Engine 5 Jul 3rd, 05 08:23 AM
Numbers matching car Pono Restoration Corner 1 Jun 17th, 04 11:22 AM
Need Help Decoding Numbers????? 68 RJ Tag Team 2 Jan 28th, 01 05:17 AM
