302 for sale - true or not? - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 13th, 07, 03:31 AM Thread Starter
On a Dutch site someone is selling what is supposed to be a 69 302 engine. Is there any way of telling it is or isn't by this picture? The only number mentioned is the casting number 3970010. I emailed him for more numbers but no response yet. It would be an extremely rare engine around here...
Dutch69Camar is offline
post #2 of 6 (permalink) Old Feb 13th, 07, 04:35 AM
parkbrau's Avatar
Re: 302 for sale - true or not?
Hard to say without getting into it. I sent you a PM regarding NL.
john
parkbrau is offline
post #3 of 6 (permalink) Old Feb 15th, 07, 10:46 AM
frank
Timing cover tab looks too close to crankshaft.
wot
frankk is offline
post #4 of 6 (permalink) Old Feb 15th, 07, 11:39 AM
DZ for 1969 on the engine code
MD for 1968-67 code
Everett#2390 is online now
post #5 of 6 (permalink) Old Feb 15th, 07, 11:59 AM
Vintage 68's Avatar
Thumbs up Re: 302 for sale - true or not?
You are going to have to look at the Suffix on the block, if it's still there, and compare the components and dates to be sure it is wahat he says.
The timing cover tab is for an 8" damper - but, it has a bolted on tab, Z's were welded. The cover could have been removed/replaced for some reason like changing the timing chain or during a rebuild - hard to tell.
The block is a Flint casting, so that is correct for a DZ.
The heads are the HP '186 'type' that would be used on a '69 DZ.
Those look to be the correct, non-polished, Z valve covers - hard to tell.
The pulleys in the lifter galleys also look to be deep-groove type, may be original to engine.
I think checking the data on the front pad, checking for a partial VIN on the pad or down by the oil filter on the bellhousing flange and/or pulling a valve cover to check head casting number and date would help pin it down a little without causing the seller a lot of trouble to confirm it.
Hope it turns out to be something you can use;
1968 Convertible
Some trucks
Vintage 68 is offline
post #6 of 6 (permalink) Old Feb 15th, 07, 12:14 PM
ask him for the #'s off the pulleys (sitting in the lifter valley), from what I see they don't look like deep groove (if they were that would be a +)
68 Z/28, grotto blue, protect-o-plate
67 plain jane survivor, deep water blue, protect-o-plate
SooperDave is offline
True 1969 302 DZ Block on eBay 1999Hugger Restoration Corner 15 Jan 19th, 07 08:25 PM
69 Camaro with factory 302 fendor emblems??? Blk69 Tag Team 4 Feb 13th, 06 08:51 PM
302 and 400 small blocks tredman Performance 17 Jan 14th, 04 03:32 PM
true hp 69 302 yellow69z28rs Performance 12 May 28th, 03 05:10 AM
true HP of 302 RAGTOP68 Engine 8 Aug 4th, 00 03:08 PM
