Vacuum Gauge Tuning - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 13th, 07, 01:14 PM Thread Starter
Paul
Vacuum Gauge Tuning
So I fired my 383 (GM 962 cam, edelbrock heads) with the modified LT1 intake, made sure everything was OK, adjusted the timing (computer controlled), fuel map, readjusted the rockers, etc. I was slightly concerned that the modified LT1 intake wouldn't seal, so I have been checking and rechecking everything to make sure that I don't have a vacuum or coolant leak.
I ran it yesterday and hooked up a vacuum gauge, got a perfectly steady 14-15 inches (which is what it had when I ran a QJet) at a steady 700 RPM idle. I guess a steady idle and vacuum gauge reading verifies no vacuum leak and correctly adjusted rockers huh? I guess I should move onto something else and stop "over thinking" the engine tune?
Best of 1.55 - [email protected]
paulm is offline
post #2 of 6 (permalink) Old Feb 13th, 07, 01:22 PM
DjD
DjD's Avatar
Re: Vacuum Gauge Tuning
Hey Paul, look this page over, it will give you that warm and fuzzy you are looking for...
http://www.centuryperformance.com/vacuum.asp
...Dennis
DjD is offline
post #3 of 6 (permalink) Old Feb 13th, 07, 01:29 PM
When I ran the same cam w/Q-jet & Holley 3310, 900 rpm w/16 in./Hg.
post #4 of 6 (permalink) Old Feb 13th, 07, 01:36 PM Thread Starter
Paul
Thanks guys!
So why did you set the idle to 900 RPM? That seems a little high?
paulm is offline
post #5 of 6 (permalink) Old Feb 13th, 07, 03:20 PM
The engine worked better there when setting at the starting line at idle and nailing the throttle to WOT to take advantage of the looser convertor.
Plus, it had another inch and a half of vacuum than at 750 rpm. Better response from the engine.
post #6 of 6 (permalink) Old Feb 13th, 07, 03:22 PM Thread Starter
Paul
Cool, so 14-15 sounds about right at 700 RPM huh?
paulm is offline
Whats with my timing 43* Rayzz Performance 3 Oct 18th, 06 04:53 AM
total timing blue67 Performance 12 Sep 10th, 06 11:27 AM
Small jets but still seems rich. camaro_fever68 Performance 10 May 24th, 06 05:46 AM
getting too hot noels69 Heating & Cooling 14 May 31st, 05 08:53 PM
Vacuum advance or not??? Ethan67 Performance 55 Apr 9th, 04 06:50 PM
