what is quench?? - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 13th, 07, 04:16 PM Thread Starter
what is quench??
Easy enough!
dubs68camaro is offline
post #2 of 3 (permalink) Old Feb 13th, 07, 04:44 PM
Re: what is quench??
Quench means to snuff out, to put out the fire. This is accomplished in an internal combustion engine by enclosing the possible fire in an area closely bounded by cooler materials. If the cooler materials disallow the fire from happening, you will have quenched it. The cooler you can keep the metal, the less chance of detonation.
Here's an article recently posted:
http://www.popularhotrodding.com/eng...power_squeeze/
another one:
http://zhome.com/ZCMnL/PICS/detonation/detonation.html
onovakind67 is offline
post #3 of 3 (permalink) Old Feb 13th, 07, 04:58 PM
Vintage 68's Avatar
Cool Re: what is quench??
Main Entry: quench
Pronunciation: 'kwench
Function: verb
Etymology: Middle English, from Old English -cwencan; akin to Old English -cwincan to vanish, Old Frisian quinka
transitive verb
1 a : PUT OUT, EXTINGUISH b : to put out the light or fire of <quench glowing coals with water> c : to cool (as heated metal) suddenly by immersion (as in oil or water) d : to cause to lose heat or warmth <you have quenched the warmth of France toward you -- Alfred Tennyson>
2 a : to bring (something immaterial) to an end typically by satisfying, damping, cooling, or decreasing <a rational understanding of the laws of nature can quench impossible desires -- Lucius Garvin> <the praise that quenches all desire to read the book -- T. S. Eliot> b : to terminate by or as if by destroying : ELIMINATE <the Commonwealth party quenched a whole generation of play-acting -- Margery Bailey> <quench a rebellion>
In terms of engine design it is the distance between the top of the piston and the bottom of the head.
This actual distance or clearance can be somewhat theoretical in engine design, as the actual piston travel in dynamic operation will be slightly farther (or longer) than the initial static measurements taken during engine assembly. This can also be effected by engine operating speeds in the upper RPM ranges.
Stock engines will commonly have quench values in the 0.060+ ranges, many performance builds try to get this into the 0.030~.050 range to increase compression squish effect and engine output.
Most endurance engines will have clearances closer to 0.045+ to prevent issues at high engine speeds.
Here is a good article form CHP discussing quench as applied to our use - http://www.chevyhiperformance.com/te...earance_guide/
Hope this helps;
1968 Convertible
Some trucks
Vintage 68 is offline
Good Article on Compression & Quench Steve69SS396 Performance 3 Feb 10th, 07 06:03 PM
DZ spec build..quench question ChuckD Engine 10 Oct 29th, 06 08:42 PM
Quench Concern, Which Head Gasket eville Performance 15 Feb 5th, 06 10:15 PM
Head Gasket Material (Copper) & Quench??? camaroman7d Performance 11 Dec 7th, 03 06:15 AM
355 quench and compression FlapsFive737 Performance 11 Oct 10th, 00 02:54 PM
