383 stoker - Team Camaro Tech
post #1 of 9 (permalink) Old Feb 13th, 07, 09:15 PM Thread Starter
383 stoker
I just bought a 67 Camaro that has a 383 stoker motor can someone tell me what kind of engine is that ? is it a 350 with a differant crank and will small block parts fit it like value covers
THANKS TEAM CAMARO
phat69camaro is offline
post #2 of 9 (permalink) Old Feb 13th, 07, 09:23 PM
Harley
wiskeesour's Avatar
Re: 383 stoker
a 383 is pure SBC! meaning 1985 and older parts will work great if you motor fits in this catagory of year. some 85 and newer parts will work, but do your homework first. probably one of the easiest motors to build and work on.
a 383 is a .030 bore 350, with a 400 SBC crank. this motor can be a tork monster built on the cheap>> if done smartly.
EDIT: didnt proofread before I posted. a 383 is a .030 over bore with a 400 crank. sorry
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #3 of 9 (permalink) Old Feb 13th, 07, 10:51 PM
Re: 383 stoker
A stock 4" bore and a 3.75" stroke will net you 377 cubic inches, bore that .030" and get 383 cubes, go .060" over and you're up to 388.
onovakind67 is offline
post #4 of 9 (permalink) Old Feb 13th, 07, 10:55 PM
Harley
wiskeesour's Avatar
Re: 383 stoker
try this site out.
http://www.chevymania.com/tech/383.htm
Thanks Chief.
post #5 of 9 (permalink) Old Feb 13th, 07, 11:13 PM
Re: 383 stoker
Originally Posted by wiskeesour View Post
With statements like these -
A basic short rod 383 will live to 5500 and a 5.7" rod motor will go to 6500...A stock oil pan will be sucked dry by a high volume pump @ 4500 RPM under hard acceleration...In an engine a longer rod can make more rotational TQ from the same piston force because it's a longer lever!
- I would tend to believe that the chevymaniac hasn't done his homework very well.
post #6 of 9 (permalink) Old Feb 14th, 07, 02:41 AM
Harley
wiskeesour's Avatar
Re: 383 stoker
that may be true. lol but the block specs are what i was refering to. and I dont use a high volume pump. it sux 7hp from a decent 350 when a stock pump only takes 3hp and still get the same oil pressure. witnessed it on the dyno.
Thanks Chief.
post #7 of 9 (permalink) Old Feb 14th, 07, 09:54 AM
Re: 383 stoker
You may know this, and it was just a type"0". It is called a "STROKER" motor. This is because the stroke has been increased by using a crankshaft with a longer stroke. Case in point: A 383 is a 350 engine, that is bored over by .030", and uses a 400 crankshaft. A 350 has a stroke of 3.48 inches, where as a 400 has a stroke of 3.750 inches.
TJS69 is offline
post #8 of 9 (permalink) Old Feb 14th, 07, 09:57 AM
Re: 383 stoker
A 383 is a .030 over 350 block with a 3.75 crank. It's simple math. A standard bore 350 with a 3.75 crank would be a 377 just as onovakind67 stated.
mgt999 is offline
post #9 of 9 (permalink) Old Feb 14th, 07, 12:04 PM
Re: 383 stoker
phat69camaro,
383's are great motors...I'm biased because I run one. The 383 is a very popular hot rodder motor. It's kind of a mutt, but a good one. It was a way to throw some extra cubic inches at a 350 motor. They can be built to be major power producers if done right. Mine is a technological dinosour. 12.5/1 comp., JE forged pistons, H-beam rods, forged steel crank, (1960's) 461 Feulie Heads fully ported with 2.02/1.6 stainless valves, .585 lift solid flat tappet cam, Team G intake, modified 750 double pumper carb. It runs into my 7200rpm rev limiter like a raging bull. 11.9sec at 116mph in the 1/4 in a 3500lb 69 Firebird with full exhaust, and regular street 235 tires fighting traction all the way. And my motor is by no means a STRONG one compared to what people are running today. If it's built well, it should serve you well.
George
gschuld is offline
Smokey's SY1 cross ram on strong 383? gschuld Performance 9 Nov 27th, 06 02:31 PM
327 or 383?.......rpm or torque? makoshark Performance 25 Jun 4th, 06 02:18 PM
383 build-which cam tumper Performance 20 Aug 31st, 05 07:44 PM
HEI problems - 383 popping update/help 67RS502 Performance 9 Jul 29th, 05 05:10 AM
350 vs. 383 travis Performance 5 Aug 1st, 02 03:29 PM
