hood clearence - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 14th, 07, 09:22 AM Thread Starter
hood clearence
I have a 69 with a cowl hood and the RPM Airgap intake and holley carb . They clear ok. I bought a 67 with a flat hood. Will the same combo on the 69 clear the flat hood? All help appreciated. Thanks, Wayne
wayne payne is offline
post #2 of 4 (permalink) Old Feb 14th, 07, 10:05 AM
Chris
Re: hood clearence
Depends on a few things such as motor stands, drop base air cleaner, filter height.
I have a SBC with a RPM intake, Edelbrock 600 and a drop base air cleaner with a 3" K&N filder & K&N open element (flow through) top. It barely clears my flat hood on the front side of the air cleaner. Less than 1/2. more like 3/8 - 1/4 inch.
I THINK the air gap and the RPM are the same height. Someone else might know better.
1969 Camaro
Electric Blue Lacquer Paint
355/400 HP, M-21 4-Speed, 8.5 10-Bolt 4:11 Posi
Cal69 is offline
post #3 of 4 (permalink) Old Feb 14th, 07, 10:54 AM
Re: hood clearence
The air gap and rpm are the same ht. Mine cleared too, but again with an aftermarket drop base air cleaner.
If you use a original style cowl induction air cleaner, that could be your downfall. You might try searching for "cowl clearance" or stuff like that, see what you find. This has been discussed lots of times, I seem to recall people having to use different thinner gaskets to seal the air cleaner to the hood?
post #4 of 4 (permalink) Old Feb 14th, 07, 12:57 PM
Re: hood clearence
Vic Jr. here with a drop base cleaner and a flat hood, no issues.
68 Camaro~LSx ~all motor
Cowl Hood Not lining Up Ken Miele Body Shop 15 Apr 11th, 06 02:25 PM
Door Hinge & Remount Question Dwight's Z/28 Body Shop 3 Oct 9th, 03 03:26 PM
1968 door alignment Steve W Body Shop 5 Sep 9th, 03 05:15 PM
Adjustment to fender? Winch Body Shop 4 Mar 10th, 02 02:46 PM
Never ending spacing problem tl757 Body Shop 6 Jan 26th, 02 09:56 AM
