7801149 Smog Pump Question - Team Camaro Tech
post #1 of 2 (permalink) Old Feb 14th, 07, 12:24 PM Thread Starter
Hello, I need to learn how to read the date code off a smog pump. I have a dated pump that reads 7 H 16 1, If anybody can help I thank You!! Jimi
jimi302z28s is offline
post #2 of 2 (permalink) Old Feb 15th, 07, 02:25 AM
Re: 7801149 Smog Pump Question
The pump date should look something like 13991S. That would decode as the 139th day of 1969, assembled on first shift. It will be stamped in a small machined pad on the pump. I don't recognize the numbers you got listed, but I'm not final answer on pumps, either. Good luck!
buenymayor is offline
dumb question about clocking Mech Fuel Pump Brad74 Engine 6 Mar 21st, 06 08:10 PM
Electric fuel pump question bezo89 Performance 13 Feb 22nd, 06 09:03 PM
How to remove the Smog Pump from TPI motor antman985 Performance 5 Dec 5th, 05 09:37 PM
Water Pump question. james7773 Engine 8 Apr 9th, 05 09:25 PM
fuel pump question? hi-po327 Tech 2000 2 Jan 6th, 01 05:47 PM
