How in the HELL do you get freeze plugs out????????????????????????????? - Team Camaro Tech
post #1 of 17 (permalink) Old Feb 14th, 07, 07:26 PM Thread Starter
I know I can get them in okay......I just can't get them out!!!!!!!
dubs68camaro is offline
post #2 of 17 (permalink) Old Feb 14th, 07, 07:40 PM
Russ
Re: How in the HELL do you get freeze plugs out?????????????????????????????
I bang them on one side with a drift pin to get them to spin then grab it with a big pair of channel locks. sometimes they end up going all the way through with out spinning but no big deal you can still grab it with the channel locks and pull them out when that happens
Russ
1969 RS conv,hugger orange,396 4 speed,373 12 bolt posi.
19694speed is offline
post #3 of 17 (permalink) Old Feb 14th, 07, 07:46 PM
DjD
DjD's Avatar
I typically don't mix hammers and screwdrivers but occasionally the 2 work together well... If you put an "old" straight blade screwdriver on the edge of the core plug and tap on it with a hammer it will turn the plug in the hole it's in... Should be easy to figure out from there...
...Dennis
DjD is offline
post #4 of 17 (permalink) Old Feb 14th, 07, 08:34 PM
chris
kain13's Avatar
BFH and alot of cussn
kain13 is offline
post #5 of 17 (permalink) Old Feb 14th, 07, 08:39 PM
Mitch
Lost in the 60's's Avatar
A gas wrench works really good too....
...38 Chev coupe, street rod
...54 Chev 210 coupe
...62 Impala SS, driver/project
...67 Camaro, ss/rs LA built driver/project
...66 Chevelle SS, Atlanta built 138 driver/project
...69 C10, cab and clip may end up on the '89 rollback
...70 Chevelle SS, Canadian documented Z25 project
Lost in the 60's is offline
post #6 of 17 (permalink) Old Feb 14th, 07, 08:50 PM
drill, screw, slidehammer.
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is offline
post #7 of 17 (permalink) Old Feb 14th, 07, 09:09 PM
Gary
Knock them thru and use a long-nose vise grips. Get a good hold and you can pull them out fairly easily, but you may have to bend them up pretty good.
Gary Adrian
FCS Harmony Racing
Momma always told me not to look into the eyes of the sun.
"But momma, that's where the fun is!"
Busted Knuckles is offline
post #8 of 17 (permalink) Old Feb 14th, 07, 09:24 PM
a big channel lock works the best.
knock them into the block with a hammer and a punch, then grab them backwards with the channel lock and "flip" them out using the lip around the hole as a fulcrum to pry them thru.
it's so easy, that you will verbally curse at yourself for not figuring it out.
you don't plan sincerity.
novaderrik is offline
post #9 of 17 (permalink) Old Feb 14th, 07, 09:40 PM
Berry
Dynomite!
Its cheaper to be poor!
BERRY251 is offline
post #10 of 17 (permalink) Old Feb 15th, 07, 05:47 AM
Process doesn't seem to have changed in the last 50 years or so.
TC # 349
zdld17 is offline
post #11 of 17 (permalink) Old Feb 15th, 07, 11:58 AM
Jeff
Talking Re: How in the HELL do you get freeze plugs out?????????????????????????????
Fill the block with water and place outside...at least here in the northeast..next day they will be out.
Ratpack is offline
post #12 of 17 (permalink) Old Feb 15th, 07, 12:22 PM Thread Starter
That's actually pretty funny. I was also thinking about drilling through my cylinder walls and knocking them out with a punch......then welding the holes back up!!!
post #13 of 17 (permalink) Old Feb 15th, 07, 12:44 PM
Steps
It has been known using the hammwer and screw driver method to hit hard and go right thru and hit the cylinder wall by inexpecianced ppl...all forcew no care...
Using a drill bit 1st, no need to go all the way thru, just enough to make the wall thin, then use the hammer /screw driver method....with the screwdriver thru the hole, just off center the plug can then be flicked out.
Steptoe is offline
post #14 of 17 (permalink) Old Feb 16th, 07, 06:17 PM
i`m all about the slide hammer meathod mentioned above...
kustomwerker is offline
post #15 of 17 (permalink) Old Feb 16th, 07, 08:06 PM
Royce
By the time you drill the hole for the slide hammer you could already have the plug out using channel locks. As mentioned tap the plug in and then gar it with either vise grips or channel locks, I like to use a small block of wood as a leverage point and out comes the plug. It is really VERY simple. You do not need to pound on them to get them out of the hole.
Royce (NO XQSSS) Bradley
camaroman7d is offline
oil in/around plugs ace's68 Engine 3 Nov 1st, 06 07:10 PM
Tuesday's Humor Everett#2390 Bench Racing 2 Sep 19th, 06 09:50 PM
Picture of my spark plugs...please look supv26 Engine 2 Jun 2nd, 05 12:54 PM
Freeze plugs Eric68 Engine 3 May 28th, 03 05:38 AM
Question about freeze plugs garfield Engine 6 Mar 25th, 03 08:44 AM
