Big Block Crate Engine advice - Team Camaro Tech
post #1 of 8 (permalink) Old Feb 15th, 07, 12:23 AM Thread Starter
Team, further to my previous post about rebuilding my tired old 454, I have been investigating my options for a replacement crate motor. After some research, I have narrowed my interest down to the following which are all within my budget and offer the sort of power I am after:
Shafiroff - Ultrastreet Classic 540/695
Speed-o-motive - Streetmaster 496/580
Gilbert (Sallee) - Super Street 502/625
Does anyone have any experience with any of these? Are there any others that I should be considering? Any advice or recommendations would be welcome.
AussieCamaroOwner is offline
post #2 of 8 (permalink) Old Feb 15th, 07, 04:18 AM
Harley
wiskeesour's Avatar
Re: Big Block Crate Engine advice
Shafiroff is a good motor. scott has been building motors for a long time.
I have been doing ALOT of research on motors cause I like to build all mine but, Reher-morrison seems to be popping up at the top of my list pretty often. Second to them is bill mitchell at the engine shop third is Jon barrett. I am friends with Jon Barrett. He probably has the best bang for the buck I have found......street car wise anyway.
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #3 of 8 (permalink) Old Feb 15th, 07, 08:24 PM
World Products has the best selection of BB crates and offers a 24month,24000 mile warranty.
68VertSB2.2 is offline
post #4 of 8 (permalink) Old Feb 17th, 07, 07:16 AM
Cool Re: Big Block Crate Engine advice
I have been doing ALOT of research on motors cause I like to build all mine but, Reher-Morrison seems to be popping up at the top of my list pretty often. ...
I can scond Shafiroff as a reputable builder my brother bough one his 555's and is still beating on it. Reher-Morrison has been building not only hot street motors but are well known for building motors for many pro and super stock competitors. I am thinking of them or Pat Musi as potential builders of my next max cube short block as I have little experience with long arm tight clerance strokers.
Larger Dave
Larger Dave is offline
post #5 of 8 (permalink) Old Feb 17th, 07, 08:12 AM
Tony
Wow, those engines are a bit more hp and tq than what you were originally after out of yours.Make sure your drivetrain can handle 695 ft lbs!
67 Camaro- 427BB, TKO 600, 3.55 12 bolt etc.etc.
italiano362 is offline
post #6 of 8 (permalink) Old Feb 17th, 07, 08:26 AM
Doug
thedugan's Avatar
Send a message via Yahoo to thedugan
It's not a crate motor but if build a big block this is the motor
http://www.carcraft.com/techarticles...evy/index.html
-Doug
68 RS/SS Conv
67 Coupe
thedugan is offline
post #7 of 8 (permalink) Old Feb 17th, 07, 03:48 PM Thread Starter
Italiano, you are right, but when I look at what my budget is, (around $12 - $15K AUD) , it seems that I can get a lot more bang for my buck. Like I said, I am investigating all my options. I am looking to do all the required mods as part of the rebuild. ie, sub frame connectors, solid body mounts, 9 inch with a 4-link, etc.
With a ZZ502 costing around $14K AUD from Eagles or Amcap, I am pretty confident I can get one of these other motors into the country for the same or less, with obviously more power.
post #8 of 8 (permalink) Old Feb 17th, 07, 07:34 PM
Just another option on the GM crates.. Albury Speed and Marine sell them too. I think they may have repaired warranty engines that might save a few bucks.
Not 100% sure, just something I remember hearing.
http://www.enginemaster.com.au/engines.htm
BlackoutSteve is offline
Who's got Big block springs in a small block? mnm99 Brakes, Suspension & Steering 1 Sep 8th, 06 01:22 PM
Is this a Big Block Car? tonyvol Tag Team 8 Oct 10th, 05 07:13 PM
Big Block Front Springs jamesriediger Brakes, Suspension & Steering 6 Jun 12th, 05 12:13 AM
Big Block Motor Mounts POCO Engine 10 Jun 11th, 05 09:12 PM
BB frame mounts further forward than small block camcojb Engine 24 Jun 28th, 03 10:23 AM
