installing cam bearings - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 15th, 07, 05:36 PM Thread Starter
I know the oil holes have to be lined up. I'm just wondering if you install them dry or with some kind of lubricant on the journal side??
I'm guessing no so they don't spin but...........
dubs68camaro is offline
post #2 of 3 (permalink) Old Feb 15th, 07, 06:37 PM
Vintage 68's Avatar
Thumbs up Re: installing cam bearings
There's usually a little oil left on the area from what I sprayed on after completely cleaning the block I got back from the machine shop.
I take a clean lint-free cloth and wipe the area to remove any dust or other debris and then drive then in with the tool.
Check each of the oil holes, the block bearing bores and their lead edges very carefully, I've found small burrs and other defects on many that might have damaged the bearing if I tried to install it without removing the defect.
I don't remember anyone telling me or seeing any other machinist pre-lube them in any way before installing.
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 3 (permalink) Old Feb 15th, 07, 06:53 PM Thread Starter
That's kinda what I thought, but better safe than.......
Cam Bearings Shot? freebird Engine 5 Nov 6th, 06 05:05 PM
Cam Bearings not straight new block coleman68 Engine 12 Oct 24th, 06 06:17 AM
Cam selection help Planet Camaro Performance 33 Jun 24th, 05 06:45 PM
cam bearings install - position of oil holes caribbean camaro Engine 5 Jan 30th, 03 08:54 AM
274xe vs. hot cam on vortecs czar Performance 20 Jul 16th, 02 12:01 PM
