Necessary to take out inner spring? - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 16th, 07, 03:41 PM Thread Starter
Patrick
I'm building a 305 with stock heads and springs. Is it necessary to take out the inner spring while breaking in the cam? The cam is not that big, just a step above stock.
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
post #2 of 6 (permalink) Old Feb 16th, 07, 04:17 PM
Re: Necessary to take out inner spring?
If you can assure that you go straight to 2500 for 30 min or so , you can do it without removing he inner, but if not , I would . Never knows what is gonna interupt the breakin process. You some break in lube and maybe fill crank with Rotella . You are gonna have to change oil anyway to get all he moly lube out of the pan anyhow. Add the GM EOS for safety also.
TC # 349
zdld17 is offline
post #3 of 6 (permalink) Old Feb 16th, 07, 04:22 PM
Hydraulic flat tappet cam ?
Just above stock ?
No you do not need to.
That is done with Solid flat tappet cams.
Roller cam Hydraulic or solid doesn't need to either.
68 Camaro~LSx ~all motor
post #4 of 6 (permalink) Old Feb 16th, 07, 05:15 PM
Bill
Stock springs are only single springs, there is no inner to remove. You might have a "damper", but no inner spring.
Make sure that the stock springs will work with your cam, most upgrade cams, even the smallest ones, need a different spring to avoid coil bind.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #5 of 6 (permalink) Old Feb 17th, 07, 09:53 PM
Removing inner springs and installing lighter pressure break-in springs is only needed on agressive lift flat tappet cams. Yours should be fine without it. I am hearing that many folks (and manufacturers) recommend using Desil oil for break-in since it has a high zinc content. Someone else mentioned an additive which may be zinc as well. Run it up to 2 - 2.5K RPMs and keep it there for 20 minutes. Then tune it up and run it for a bit. Change the oil soon after as the filter will catch all sorts of goo and clog it up quickety quick.
dnult is offline
post #6 of 6 (permalink) Old Feb 18th, 07, 06:56 AM Thread Starter
Patrick
Thanks guys.
383 IS SOLD!
Building a 489BBC
Coil Springs Help ? rookie68camaro Brakes, Suspension & Steering 32 Dec 13th, 06 08:15 AM
Edelbrock RPM springs STM69 Engine 51 Mar 8th, 06 11:37 AM
Please post pics of your cars' stance after new leaf springs poloz28 Brakes, Suspension & Steering 29 Mar 11th, 04 09:58 AM
69 front coil spring install ken69 Brakes, Suspension & Steering 6 Nov 1st, 02 07:42 AM
Landrum spring adjusters jmar Brakes, Suspension & Steering 14 Jul 18th, 02 06:36 PM
