Fuel Tank Install - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 16th, 07, 03:59 PM Thread Starter
Rene
rsbecool's Avatar
Fuel Tank Install
Should a new fuel tank be flushed or is it ok to install right out of the box with no prep?
68 rs 350
M-20 4-speed
10 bolt 8.5 3.23
TC #24
rsbecool is offline
post #2 of 6 (permalink) Old Feb 16th, 07, 04:01 PM
Eric
Re: Fuel Tank Install
I have the same question, and also, the nitrile steel tanks from summit, should they be painted or coated first? I m concerned about adhesion because of the gavanized coat......any opinions?
'68 Coupe 383 Small Block
4 speed Muncie (M 21)
12 bolt rear end (4.10)
Old school slappers
Old School L-60 Mickey Thompson's
EC's 327 is offline
post #3 of 6 (permalink) Old Feb 16th, 07, 08:05 PM
68driver57's Avatar
You never know how long they have been sitting around. It's not like they make thousands of these, so expect some contamination from shelf life. I would not only flush it but coat it as well. Since you're goin to all that trouble why take a chance? POR makes a good product to prep and coat your gas tank.
68driver57 is offline
post #4 of 6 (permalink) Old Feb 16th, 07, 09:12 PM
I've always installed them right out of the box without any problems.
go2fast is offline
post #5 of 6 (permalink) Old Feb 17th, 07, 05:12 PM Thread Starter
Rene
rsbecool's Avatar
This is a new SS tank from OER. I was going to install it right out of box but thought I should check to see how everyone else was handling it.
68 rs 350
M-20 4-speed
10 bolt 8.5 3.23
TC #24
rsbecool is offline
post #6 of 6 (permalink) Old Feb 17th, 07, 09:17 PM
i`ve used a ton of tanks from spi...i`ve never flushed them out...only problem i`ve ran into is the lack of a baffle in one of them...you should be good to go outta the box, but if it makes you feel better, run your hand on the bottom to feel for particulate...if crap`s gonna get into the tank, it`ll get in through the same hole as your hand...
kustomwerker is offline
Factory Tach and Fuel gauge install 69 wtz10 Interiors 15 May 29th, 18 03:40 AM
Fuel Tank Hot 67 Performance 9 Nov 14th, 06 05:41 PM
Fuel Tank w/ sump South Side Goons & Hitmen Engine 1 Aug 13th, 06 06:11 PM
Fuel Tank Woes camaroskip Troubleshooting 5 Dec 10th, 04 03:59 AM
fuel tank rust cturner Tech 2000 2 Feb 1st, 01 08:48 AM
