SBC to BBC in a 68 - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 16th, 07, 09:24 PM Thread Starter
Paul
SBC to BBC in a 68
Ok i've been putting together a 454 for my wifes 67 chevelle that we're redoing and i'm starting to think hmmm that would look nice in my 68 camaro instead of the small block. so i mention it to the wife and low and behold she's not opposed to the idea. so what am i gonna need?
I figure different mounts, headers, radiator?(theres a 3 core in it), dump the th350 and go to a th400 so a diff crossmember, driveshaft(shorter??), maybe a diff brake booster? anything else??
"Lets Ride"
Pauly is offline
post #2 of 7 (permalink) Old Feb 17th, 07, 05:32 AM
Re: SBC to BBC in a 68
I ran a BBC in my '69 for years with the SB frame mounts and a TH350. However, to do it right, you'll need frame mounts, heater core and cover, different exhaust manifolds/headers, different fan shroud. There are numerous other small parts you'll need, but those are the major ones. The stock brake booster should still work unless you've got tall valve covers. I can't say for sure since my car had manual brakes when I was still running on the SB frame mounts. You've got a PM.
buenymayor is offline
post #3 of 7 (permalink) Old Feb 17th, 07, 06:18 AM
Craig
Will probably need to change the front springs as well. I looked into doing this with my car a couple years ago and its quite a project. Others on here have done it...and done it right. So hopefully they will chime in.
thorpe67RS is offline
post #4 of 7 (permalink) Old Feb 17th, 07, 06:25 AM
I am doing this now.springs, radiator,heater core,mounts and brackets,hoses,brackets for power stering,headers ,fan and shroud. good luck
ed mccann is offline
post #5 of 7 (permalink) Old Feb 17th, 07, 06:30 AM
I did this on my '68 - 350 to a 468. You're pretty much on the right track, it sounds like. Mounts and crossmember are the biggies. New rad, of course. Heater core and cover are a bit of a pain.
Plenty of small parts as you go along, but all in all, it's fairly easy.
Dave F. in Rhode Island
Chevy-SS is offline
post #6 of 7 (permalink) Old Feb 17th, 07, 06:40 AM
Pauly I sent you a PM with part numbers and photos of the swap.
Larger Dave
Larger Dave is offline
post #7 of 7 (permalink) Old Feb 17th, 07, 07:09 AM Thread Starter
Paul
Dave thats awesome. All the info i could want. That should possibly be a sticky (Mods--hint, hint) I love this site. i've been pretty inactive the past year or so and here i need some info and you guys come through thanks
Larger Dave
"Lets Ride"
Pauly is offline
Need help with correct engine mounts (towers off frame) for '68 BBC dubs68camaro Engine 10 Jan 21st, 07 01:29 PM
Merlin 632 BBC (800Hp) in a 68 street driven cluxford Engine 5 Dec 13th, 06 10:23 PM
68 BBC Power Steering Pump cjuetten Brakes, Suspension & Steering 5 Jun 29th, 06 08:39 PM
IS bbc smog set up same as SBC...need help 69RS/SS396ragtop Restoration Corner 11 Dec 28th, 05 04:09 AM
bbc tunnel ram top same as SBC tunnel ram top? 67stang Engine 1 Nov 22nd, 05 07:28 PM
