396 water pump & power steering - Team Camaro Tech
post #1 of 1 (permalink) Old Feb 17th, 07, 01:45 PM Thread Starter
wade
does all 396 have short or long water pump? I have a 350 hp 396 car and it has a (water pump was missing so I got a replacement from Napa and that is what I got) long on it and pulleys are not working. also I got big block P/S brkt kit from Ground Up and have had 3 pumps (2 from NAPA & 1 from ground up) and the adjustment bracket does not bolt up to the pump without hitting the return line inlet on pump- has anyone had this problem? do I bend it to fit? what is right pump? Napa has one that comes out in the middle of the pump but then it hits exhaust manifold. any on line help with pic's?
wildwade is offline
Power steering pump mounting AZ1967SS Engine 12 Dec 21st, 06 10:08 PM
68 BBC Power Steering Pump cjuetten Brakes, Suspension & Steering 5 Jun 29th, 06 08:39 PM
Need help with power steering pump 6D9 Performance 7 Aug 28th, 04 11:06 AM
Will This Power Steering Pump Work? Go69 Engine 1 Feb 9th, 04 08:25 AM
406 w/long water pump, power steering and alt.? 1968camaro123 Engine 3 Mar 27th, 03 04:38 PM
