tuning dual holleys on a 355 w/ high rise intake? - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 17th, 07, 08:15 PM Thread Starter
Darko
I bought a 67 camaro with dual vac secondary holleys on a weiand high rise intake.
Its got camelback heads
11:1 compression
somewhat lumpy cam
headers
350 trans
3.55 rear gear
There is hesitation when driving it around, and if you nail the throttle when the car is at a stop the carb will backfire and the motor will shut off. When I took off the bonnet & air filters the tops of the carbs looked black & oily. It has an adjustable fuel pressure guage and thats set around 10psi if I remember right.
Any idea what the cause of the backfiring is? How to start tuning it?
darko is offline
post #2 of 3 (permalink) Old Feb 18th, 07, 04:18 AM
Re: tuning dual holleys on a 355 w/ high rise intake?
That's a lean back fire. You need to richen the accelerator pump's shooters/squirters.
BlackoutSteve is offline
post #3 of 3 (permalink) Old Feb 18th, 07, 08:05 AM
10 PSI is a lot I am suprised you are not dumping fuel the needle and seat usualy hold to 9 PSI I always set a street [email protected] 7 to 8 PSI. BlackoutSteve is right you probably have a lean bacfire. You can buy a tune kit that changes the accel. pump ramp to a more agreesive ramp. Also you really need to set the timing up correctly first before you tune the carbs. To much initial timing will also cause carb spitting. Alot of people turn up the timing to compensate for a flat spot or hesitation in the fuel curve. I like running a timing curve on eng. like yours that has 15 degrees initial 36 total and I bring full centrifigal adv. in as early as I can without making the eng ping. You do that by adj. spring rate. Once that is set you can tune the fuel curve properly. If I were you I would contact Pro systems carb shop in Spring Lake Mi. 727-490-5717. They will be more then happy to point you in the right direction and get you tuned in they can sell you all the tunning kits and help dial you in. They are about the best at what they do and I dont think they are to far from you.
Bolt is offline
Need Help with valve adjustment on Small Block jsabowabo Engine 18 Jan 13th, 07 09:12 PM
Lobe Separation Angle questions 69ProTouring Performance 19 Oct 10th, 05 06:41 PM
1st timeslip from new combo, please comment Camaro76350 Performance 5 Nov 16th, 03 01:52 PM
Intake shopping. Should I go single or stay dual plane? Chris88Z Performance 23 Nov 11th, 02 06:25 PM
need help with some high altitude/high performance tuning on my partial race car 1Fast69chevy Performance 10 Jan 15th, 02 02:01 PM
