2 piece timing cover - Team Camaro Tech
post #1 of 8 (permalink) Old Mar 1st, 07, 04:33 PM Thread Starter
Brad
I was looking in to buying this cover :
http://store.summitracing.com/partde...2&autoview=sku
But not sure what this mean,
Summit notes: "Stamped aluminum .090 in. thick. Only a nylon cam button may be used. May require extra gasket thickness or spacer for a short water pump to clear"
Im using long w/p so thats o.k. But the nylon cam botton? I dont know if I have one and if I dont does it matter?
Any help would be great. Brad
Most recent 01/01/10
spideynut is offline
post #2 of 8 (permalink) Old Mar 1st, 07, 05:51 PM
bowtie1Z28's Avatar
Re: 2 piece timing cover
Don't have any experience with that particular cover but if you are using a long pump you should have no problems. Short style pumps fit very close up to the timing cover. With this Edlebrock unit it looks like you have an extra gasket plus the thickness of the second plate that has the oil pan sealing lip on it. You would only need the nylon cam button if you are running a roller can otherwise it is not needed. Anything other than the nylon button will wear thru the aluminum.
bowtie1Z28 is offline
post #3 of 8 (permalink) Old Mar 1st, 07, 06:28 PM Thread Starter
Brad
All solid here thanks for the info. I think Im going to order it to go with my new pan.
post #4 of 8 (permalink) Old Mar 1st, 07, 06:56 PM
I'm using that cover. If you paint it, no one will ever know. The water pump hides the Edelbrock script. It works fine. My only gripe is that if you remove it down the road, it's hard to find a replacement gasket. I ended up using RTV.
BPOS is offline
post #5 of 8 (permalink) Old Mar 1st, 07, 08:31 PM Thread Starter
Brad
Good point on the gasket. Im not really one for name brand it doesnt really matter IF the products are equal. I have a 23.00 crome one thats giving me a bad time so Im assuming a 75.00 will be better?
post #6 of 8 (permalink) Old Mar 2nd, 07, 11:44 AM
Bpos I thought i was the only one with this problem finding a gasket?Made the second one out of gasket paper from there on RTV too.I hav the long water pump.No leaks with this one so far.Could not find a replacement gasket even called the company.No luck!
FastFred is offline
post #7 of 8 (permalink) Old Mar 2nd, 07, 05:53 PM
Ditto! I think I finally found the gasket "set" which included both gaskets and the balancer seal for over $20 - about a third of the price of a new cover. I think you could make the Mr. Gasket gasket for their 2 piece work, but I just gooped it and it doesn't leak.
BPOS is offline
post #8 of 8 (permalink) Old Mar 2nd, 07, 10:49 PM Thread Starter
Brad
Ya I wanted to go to the Mr. Gasket version of the 2 piece for price but I run a 8in balancer and its a no app. I going with a Milodon stock replacement oil pan and pick up.
I was just checking out Summit and are you guys saying it doesnt come with the correct gasket? Do they even make one?
Reinstalling Timing Cover; gasket question kidder03 Engine 8 Feb 18th, 07 01:04 AM
Timing Cover 8in Balancer. freebird Engine 8 Nov 16th, 06 03:31 PM
Timing chain rubbing timing cover sixtyeight Engine 4 Oct 18th, 06 01:47 PM
timing chain cover oil leak tdsk1967 Troubleshooting 4 Mar 31st, 03 03:45 PM
Comp Cams 2-Piece Timing Cover cmrib Engine 5 Jun 23rd, 00 07:08 PM
