400 Rebuild - Team Camaro Tech
post #1 of 2 (permalink) Old Mar 4th, 07, 08:17 AM Thread Starter
400 Rebuild
Pulled engine because engine was smoking at WOT. Found out crank was wiped out. Block is a 400 # 3951511-2 bolt. Now, what to do about rotating assembly? Should I go with Scat or Eagle? Stroker or not? I want to get to about 500HP. I have World Sportsman II iron heads-64CC chambers, Edelbrock 1407 750 CFM carb, and a Crane Blueracer cam
Grind Number: 300-2H
Operating Range: 2500-6500 RPM
Duration Advertised: 300 Intake / 310 Exhaust
Duration @ .050'' Lift: 234 Intake / 244 Exhaust
Valve Lift w/1.5 Rockers: .488'' Intake / .510'' Exhaust
Max Lift Angle: 109 ATDC Intake / 119 BTDC Exhaust
Lobe Separation Angle: 114
Open/Close @.050'' Cam Lift: Intake - 8 BTDC (opens) / 46 ABDC (closes)
Exhaust - 61 BBDC (opens) / 3 ATDC (closes)
Hedman 1 3/4" coated headers
What else would I need....any help appreciated...thanks,
1973 Camaro RS Z-28, Tremec 5 spd, AC, PS, PB, 3.73 rear
schildk is offline
post #2 of 2 (permalink) Old Mar 5th, 07, 05:11 PM Thread Starter
Re: 400 Rebuild
Okay, I talked to a guy at CNC today and he told me I should go with Eagle because of balancing problems with Scat. So, I have heard bad and good from both....which would you use?
schildk is offline
400 starter jrager Engine 13 May 8th, 15 07:11 AM
400 block build up SY1 Engine 5 Nov 2nd, 06 02:53 PM
400 block with 350 crank, or 350 block with 400 crank? 69z28boy Performance 16 Jun 26th, 06 10:13 AM
Turbo 400 rebuild questions bravewink Transmission & Driveline 4 Oct 6th, 03 03:48 PM
BIg Block Info I got off the web! Very long! pdq67 Performance 6 Jan 5th, 02 03:08 PM
