68 Camaro Wont Start - Team Camaro Tech
post #1 of 11 (permalink) Old Mar 5th, 07, 04:15 PM Thread Starter
Unhappy 68 Camaro Wont Start
Hey I need Help,
I replaced my starter and installed it but when I turned the Key And I hear A Click when I go under the car the little wheel inside of the starter is engaged in the Fly wheel but it doesnt turn the damn thing and it just keeps clicking I Hear that sound in my sleep hahaha lol seriously... Could someone help me please Frustrated and confused
JACAMARO68 is offline
post #2 of 11 (permalink) Old Mar 5th, 07, 04:18 PM
Re: 68 Camaro Wont Start
Welcome to Team Camaro!
Sounds like your battery is dead.
Mike68RS is offline
post #3 of 11 (permalink) Old Mar 5th, 07, 04:19 PM
battery or solenoid
dubs68camaro is offline
post #4 of 11 (permalink) Old Mar 5th, 07, 04:25 PM Thread Starter
My battery has More than 12v's Where is the solenoid at sorry im restoring this car and im learning all this stuff with my books and all
post #5 of 11 (permalink) Old Mar 5th, 07, 05:11 PM
Bendex is stuck out ? Bad starter or needs shimed.
The motor does turn over (by hand) right ?
68 Camaro~LSx ~all motor
post #6 of 11 (permalink) Old Mar 5th, 07, 05:22 PM
if the starter isnt shimmed correctly, the bendix could bind in(too tight to the flywheel)...also, are you using a 168 tooth starter with a 156 tooth flywheel???i dont even know if that would bolt in, but just a suggestion...also check your positive connection to the starter...weak conn will make the starter a nogo...
kustomwerker is offline
post #7 of 11 (permalink) Old Mar 5th, 07, 05:31 PM Thread Starter
Yes the car turns over by hand I can move the flywheel just fine the starter just keeps clicking and getting stuck on the flywheel is there A Site I can go to to show me how to properly shim the starter??
post #8 of 11 (permalink) Old Mar 5th, 07, 06:11 PM
u should be able to put a small rod(.080 i believe...i`m sure someone here knows...) between the point of the bendix gear and the recess of the flywheel gear...sometimes the shim pack will comwith this rod...autozone starters usually come with this rod, and you can probably get one from an autoelectric shop...
post #9 of 11 (permalink) Old Mar 5th, 07, 06:11 PM
Apparently, the starter is too close to the flywheel and in a bind.
Visit your local parts store and look in the Help aisle for GM starter shims in the assortment package. Usually there will be a 0.020", 0.040", and a 0.060" thick shims in the pkg. Any one of, or a combo of shims, will mocve the starter out enough to prevent binding.
The shim has a complete hole on end and a slot on the other end. Loosen both bolts, take out the outside bolt, slide in a shim with the slotted hole on the inside bolt, install the outside bolt through the shim and tighten both bolts up. Generally, a 0.020" or a 0.040" shim will cure most binding.
Its alot of work, but the correct way to shim is to remove battery power, remove the starter motor, remove the solenoid, intall the motor with a shim, and manually engage the starter drive by hand and feel/listen to its engagement. Once the drive slides in & out with ease, remove the motor, install the solenoid, install the motor with the chosen shims, wire up the solenoid, and attempt to start. You should not hear the drive pinion and ring gear on the flywheel do nothing other than "whirl." But, you can shim too much and the pinion will skip teeth, kindda like fingernails on the chalkboard.
post #10 of 11 (permalink) Old Mar 5th, 07, 06:20 PM
as a side note to everetts detailed(very cool) directions, there are straight shims and angled shims...make sure to get the correct ones for your starter...
post #11 of 11 (permalink) Old Mar 5th, 07, 06:41 PM
Just because it has more than 12 volts doesn't mean it's good. Cranking amps is whats needed. Are you sure the battery is good? Could you swap in a known good one?
Mike68RS is offline
68 camaro Windshield Wipers start, stop, blow fuse 1BADRS Troubleshooting 5 Sep 28th, 06 10:07 PM
8.5 firebird rear in 68 Camaro Litegreenmarine Transmission & Driveline 4 Sep 10th, 06 08:36 PM
68 camaro or 68 charger my camaro loves my money Bench Racing 24 Aug 24th, 06 06:28 AM
68 Camaro Paint list tronic72 Body Shop 1 Jan 21st, 06 04:20 AM
more readings I found on up-coming camaro JFINN1976 Bench Racing 2 Oct 23rd, 04 08:37 AM
