1970 Lt-1 - Team Camaro Tech
post #1 of 8 (permalink) Old Mar 6th, 07, 02:04 PM Thread Starter
Jake
1970 Lt-1
I have a 1970 1/2 Z-28 that originally had an LT-1 in it but now has a factory CE block. Is the CE still considered or built to LT-1 specs?
Thanks for the help guys!
cruisincreations is offline
post #2 of 8 (permalink) Old Mar 6th, 07, 05:24 PM
Question Re: 1970 Lt-1
Only if it is a "CE" LT-1 engine replacement, imho..
Outside of that, I really don't know?? Sorry.....
I do know that back then you could buy crate LT-1 engines tho... L-88's too...
pdq67
post #3 of 8 (permalink) Old Mar 6th, 07, 05:50 PM Thread Starter
Jake
Re: 1970 Lt-1
Thanks for the help. I have to tear into it anyway. I guess I will find out soon enough.
post #4 of 8 (permalink) Old Mar 6th, 07, 06:44 PM
Re: 1970 Lt-1
Block will probably be a 010/020 hi tin content nickel block, very desirable.
TC # 349
zdld17 is offline
post #5 of 8 (permalink) Old Mar 6th, 07, 06:57 PM Thread Starter
Jake
Re: 1970 Lt-1
I appreciate the help. I guess this is directed specifically to Don-what numbers would let me know it is a nickel block?
Thanks again.
post #6 of 8 (permalink) Old Mar 6th, 07, 08:09 PM
Re: 1970 Lt-1
He just told you!
look for them to be on the drivers side of the front of the engine behind the timing cover and probably on the back under the bellhousing if i remember right.
pdq67
PS., Numbers like "010" and "020" sort of deal, usually one on top of the other stacked cast in place...
post #7 of 8 (permalink) Old Mar 7th, 07, 08:04 PM
Norm
LT1FUN's Avatar
Re: 1970 Lt-1
This is a 1970 LT1 Z28 block (CTC Stamped) I have that shows the 010 and 020 casting numbers. Hope this helps.
69 Camaro SS X55
70 Camaro RS/Z28
LT1FUN is offline
post #8 of 8 (permalink) Old Mar 9th, 07, 01:50 PM Thread Starter
Jake
Re: 1970 Lt-1
Thanks for all the help. This is the first second gen camaro I have purchased and I am learning as I go. I appreciate it guys!
69 Camaros with 1970 Title (Strike Carryover) Mbooher Tag Team 27 Dec 24th, 06 04:49 PM
1970 402 BB 420 HP/400 Torque GOSFAST Engine 0 Aug 6th, 06 09:23 AM
Factory Stock & FAST Drags/SHOW NY,NJ,CT&MD onabudget Team Camaro Cruiz-Ins 3 Nov 16th, 05 09:32 AM
