Just drop the tank. Either use a jack to hold it or get a buddy. I bought mine from Rockauto.com and love it. Several oter guys here have used them as well. It's a easy job to do. It's nice to have a gas gauge.
-Doug:beers:
Make sure you drain as much fuel out of the tank as possible. It can be a real bear to get out with too much fuel in it. I would spend the extra money and get a Delco sender. I have heard there are a lot of problems using a reproduction one. I think I paid around $160 for mine at ground up. Good Luck!
Take your time. Even with a gal or so of gas left in the tank ( at 6#/gal) sloshing around will make it fun to remove. I used a brass drift to remove the locking ring. Have another ring and gasket handy.
Also make sure that you don't forget that little itty bitty anti-squeak liner that fits on top of the tank... lots have in the past. Just a suggestion.
If your using a floor jack to assist in lowering the tank, put a piece of wood between the tank and your jack. If you still have a few gallons of gas in the tank, you could dent your tank. Also before you lower the tank all the way, disconnect the ground wire for the sender.
Related Threads
Team Camaro Tech
2.4M posts
83K members
Since 1998
