906 Vortec Heads - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 9th, 08, 06:34 PM Thread Starter
906 Vortec Heads
Does anyone have pics of the 2 styles of exhaust ports for the 906 vortec castings"hardened seat insert and induction hardened" so I can see the difference?
Thanks Chilli
Chilli is offline
post #2 of 8 (permalink) Old Jan 10th, 08, 07:01 AM Thread Starter
Re: 906 Vortec Heads
Anyone??
Chilli is offline
post #3 of 8 (permalink) Old Jan 10th, 08, 04:13 PM
I have never heard of hardened inserts in those heads any picture I have seen of these heads from the factory the are induction hardened. The only way you can "see" the induction hardening is when the are new, the area all around the see is "blued" looking from the heat. Why are you asking????
CamaroZZ430 is offline
post #4 of 8 (permalink) Old Jan 10th, 08, 05:02 PM
Tim
77wolf10.85's Avatar
I could be wrong but I thought all 906 had hardened exhaust seats. I thought it was 062's that didn't.
Tim Smith
77wolf10.85 is offline
post #5 of 8 (permalink) Old Jan 10th, 08, 08:40 PM Thread Starter
the 906 casing were made two ways,pressed in and machined seat and induction hardened.
I have read conflicting reports that the pressed in and machined seat disrupt exhaust flow hurting performance. I would like to see the difference between the two with a picture of the exhaust port. If there is a visible difference . I obtained a set of 906 heads and would like to know what to look for.
Chilli is offline
post #6 of 8 (permalink) Old Jan 10th, 08, 10:15 PM
I would imagine that if you had pressed in seats, you would be able to top and side edges of the seats. If the seat is pressed in you should see the line where it interfaces with the head.
post #7 of 8 (permalink) Old Jan 11th, 08, 07:18 AM
Gary
If it has pressed-in seats, you'll definitely be able to see 'em. The early ones had a terrible valve job, it was practically a 90* angle into the port. The later ones are much better. All the 906's I've seen have pressed-in seats. Don't believe everything you read in the rags, either - most have retracted the statement about hurting flow. Once you've got the bowls cleaned up, short turns worked a bit and whatever chamber work you want, there won't be a nickel's difference between your 906's and the 062's.
Gary Adrian
FCS Harmony Racing
Momma always told me not to look into the eyes of the sun.
"But momma, that's where the fun is!"
Busted Knuckles is offline
post #8 of 8 (permalink) Old Jan 11th, 08, 10:40 AM Thread Starter
Now that is the answer I was looking for.
I also read that any porting would hurt flow.
Now I have done some porting on other engines I have built and it would seem that the same rules would apply to a vortec exhaust port. Smooth curves and no sharp edges would help. Does anyone disagree??
Chilli is offline
