'69 DZ302 cam - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 12th, 08, 07:28 PM Thread Starter
'69 DZ302 cam
Looking for a Standard cam for '69 DZ302 motor.
Greg M.
1969 RS Z28
grmZ28 is offline
post #2 of 7 (permalink) Old Jan 12th, 08, 07:55 PM
Eric
Re: '69 DZ302 cam
Crane makes the current GM replacement cam, which can be found here
Eric
Carburetor Rebuild & Restoration
Engine & Driveline Parts & Services
Vintage Musclecar is offline
post #3 of 7 (permalink) Old Jan 14th, 08, 05:58 PM Thread Starter
Re: '69 DZ302 cam
Hey,
Thankyou very much for the data......I'm wanting to keep motor all OEM.
Thanks again
Greg
1969 RS Z28
Hugger Orange
grmZ28 is offline
post #4 of 7 (permalink) Old Jan 14th, 08, 08:21 PM
SY1
Wink Re: '69 DZ302 cam
Greg what Eric is saying is you can order it from GM, but GM will send you the cam made by Crane. GM no longer makes this grind, but uses Crane as their supplier for it. There is no OEM 302 cam any longer unless you find an NOS one, which do appear occasionally for sale. So you might as well just buy it from a supplier like Jeg's as Eric suggests.
Clevite also offers many of the original GM grinds as well, but are a little more difficult to find unless you know the duration, lift and valve event timing info already for the cam you are looking for. I used a Clevite replacement for the last 302 1st design off-road 140 solid cam.
SY1 is offline
post #5 of 7 (permalink) Old Jan 15th, 08, 08:21 AM
Re: '69 DZ302 cam
This should be Clevite's 20-30 cam....
PN 229-1612;
294/254, .110/114, .485" lift and need's .030" lash on both sides; and this one
Elgin's;
PN E-901-P; 314/254, 114/110, .485”, Lash, .030” on both sides too.
pdq67
post #6 of 7 (permalink) Old Jan 15th, 08, 04:01 PM
Chuck
Send a message via AIM to ChuckD Send a message via MSN to ChuckD
Thumbs up Re: '69 DZ302 cam
All good options........I used the Crane Blueprint cam and recommended springs, ordered from Summit. It worked out great. Just make sure you use the "JOHNZ" method of valve adjustments. Mine are "solid sounding" if you listen close enough, but not at all noisy.
69 Z-28-Glacier Blue, X-77
ChuckD is offline
post #7 of 7 (permalink) Old Jan 15th, 08, 04:14 PM
Re: '69 DZ302 cam
Greg
Comp Cams also make an OEM replacement.
skyman51 is offline
