2 questions, Vortec guides, springs etc.. - Team Camaro Tech
post #1 of 14 (permalink) Old Jan 16th, 08, 03:15 PM Thread Starter
Patrick
1) Would stock vortec head springs work with a ROLLER cam?
2) How much would it cost (est) to get the guides cut to accept a larger lift cam?
Just wondering if I should buy Vortec heads bare and buy valves and matching springs for my cam and have machine shop perform valve job and other work VS buy them new assembled then have the guides cut? Trying to save money$
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
post #2 of 14 (permalink) Old Jan 16th, 08, 05:47 PM
Re: 2 questions, Vortec guides, springs etc..
How big of a roller cam are you looking at? A mild street roller under .480" inch lift should be no problem. You can buy the guide cutter and arbor from comp cams...I think I gave $40 for mine. No need to get new valves, but stock vortec springs are pretty weak, so you will most likely need to change them.
"This is not a cheerocracy...I make the cheercisions around here"
travis is offline
post #3 of 14 (permalink) Old Jan 16th, 08, 06:05 PM
Buy the dual cutter and open up spring pockets at the same time you mill the guide bosses for positive seal and guide height. Surely thats worth the price of a cutter. I know have cutters up to 1.625 that do this. This way you can get the correct springs for your roller cam.
TC # 349
zdld17 is offline
post #4 of 14 (permalink) Old Jan 16th, 08, 06:25 PM
Bill
Patric,
By the time you buy the heads, spend the money to have them machined, etc etc, you could probably buy a set of aftermarket heads for just slightly more and get a much better head. I personally think that the GM vortec heads are way over rated. Yes they flow good and make power but ... have you actually looked at a set to see how thin the deck surface is ? Scary if you ask me. Same with the intake mounting surface, it is hardly thick enough for about three threads of a bolt unless you use the vortec type manifold. I think the vortecs are about $600 a pair assembled, for just a little bit more you can almost get an aluminum head.
Just my opinion,
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #5 of 14 (permalink) Old Jan 16th, 08, 06:37 PM Thread Starter
Patrick
My cam has: [email protected] 0.050" 208/221, Valve Lift 474/510, 112 Lobe Center Separation
Originally Posted by BillK View Post
Patrick,
Just my opinion,
This has crossed my mind many times. The cheapest that I can get them assembled and upgraded is around $680(ScogginDickey).
Bill,(or anyone else) what other head would you recommend for a daily driven 400ci truck engine with a zz4 cam, stock dished pistons and perf rpm intake? I have everything except the heads. I was not wanting to spend over $700.
383 IS SOLD!
Building a 489BBC
post #6 of 14 (permalink) Old Jan 16th, 08, 06:49 PM
Chad
67 Plum's Avatar
Competition Products has Dart Iron Eagle 200cc angle plug heads on sale for $599.00 a pair assembled.
67 Plum is offline
post #7 of 14 (permalink) Old Jan 16th, 08, 06:50 PM
Chad
67 Plum's Avatar
Patric,
Just my opinion,
I agree 100%.
67 Plum is offline
post #8 of 14 (permalink) Old Jan 16th, 08, 06:57 PM Thread Starter
Patrick
Thanks Chad, I wrote this down.
Jim has a set of Dart Iron eagle 180's in the classifieds. Would these be better than the Vortecs? His flow#'s are:
DART:..In...Ex----------------------------------VORTEC:...In.......Ex
.300...200...158-----------------------------------.300......190.....121
.400...237.6..193.1--------------------------------.400......227.....140
.500...252.3..200.6--------------------------------.500......239.....147
.550...257.4..201.9--------------------------------.600......229.....151
.600...260.1..202.8
.650...262.3..203.7
https://www.camaros.net/forums/showthread.php?t=124473
If yall say these heads will be better for my application, I will get them!
383 IS SOLD!
Building a 489BBC
post #9 of 14 (permalink) Old Jan 16th, 08, 07:23 PM
Chad
67 Plum's Avatar
You have a Vortec intake , center bolt valve coves and Self guided rocekrs?I would rather have Jims heads.JMO
67 Plum is offline
post #10 of 14 (permalink) Old Jan 16th, 08, 07:29 PM Thread Starter
Patrick
Yep, I have all of this AND the bottom end is already assembled.....1 vote for Jim's heads
383 IS SOLD!
Building a 489BBC
post #11 of 14 (permalink) Old Jan 17th, 08, 04:54 PM
to answer the original question with an original answer that, surprisingly, no one brought up- the vortec heads came installed in trucks with roller cams, so, yes they will work with small roller cams..
as for the "thin" intake mounting surface- just use the proper vortec intake manifold (you know- so it actually seals the roof of the port instead of leaving 8 HUGE vacuum leaks) and that problem is solved.
you don't plan sincerity.
novaderrik is offline
post #12 of 14 (permalink) Old Jan 17th, 08, 06:27 PM Thread Starter
Patrick
Thanks Derrik, now if I get the vortec's I'll keep the springs. This will cut down on costs, and I like saving money!
383 IS SOLD!
Building a 489BBC
post #13 of 14 (permalink) Old Jan 17th, 08, 07:24 PM
Chad
67 Plum's Avatar
My cam has: [email protected] 0.050" 208/221, Valve Lift 474/510, 112 Lobe Center Separation.
Stock Vortec springs wont work with a .510 lift cam..480 is usually max on Vortecs due to retainer to valve guide clearance.
67 Plum is offline
post #14 of 14 (permalink) Old Jan 17th, 08, 07:31 PM Thread Starter
Patrick
Yea and if I get used heads the springs will probably be weak and need to be replaced any way. thanks Chad
383 IS SOLD!
Building a 489BBC
