383 piston explode - Team Camaro Tech
post #1 of 42 (permalink) Old Jan 16th, 08, 07:43 PM Thread Starter
Michael
383 piston explode
My piston exploded on my 383 in my garage when i was revving it to 6 grand. My cams float is around 7500. There is no piston just rings it scraped up my wall a little and it sent chunks of piston in all 8 cylinders. It also bent three valves that i just did a quick check on. There was also a mark on another piston from a valve but no detonation.
The baby only had 300 miles. The heads were also shaved .020 and the deck clearance was 0. Do you know what could cause this?
Radcannon is offline
post #2 of 42 (permalink) Old Jan 16th, 08, 07:44 PM
Harley
wiskeesour's Avatar
Re: 383 piston explode
Tell us EVERYTHING you know about the engine.
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #3 of 42 (permalink) Old Jan 16th, 08, 07:52 PM
Banned
Ron
Badbird's Avatar
What cylinder?....Cast or forged slugs?.....Piston to wall clearance?.....Lean Fuel Mixture?.....Detonation?.....Are you running NOS?
Badbird is offline
post #4 of 42 (permalink) Old Jan 16th, 08, 08:02 PM
Chad
67 Plum's Avatar
Not enough valve to piston clearance.JMO with info given.
67 Plum is offline
post #5 of 42 (permalink) Old Jan 16th, 08, 08:05 PM
free revving to 6k in the garage? why?
post #6 of 42 (permalink) Old Jan 16th, 08, 08:12 PM
AJ
Thats what i'm thinking.........
How did it send chunks of pistons in all 8 cylinders when the head seals off the other cylinders, the only way it could have sent them into the other cylinders from the bottom, which I do not think would do much damage.
can you post pics.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #7 of 42 (permalink) Old Jan 16th, 08, 08:13 PM
Free reving a motor like that will tear the end right off a conecting rod , thats why poeple loose engines in the burnout box when they don't run rev limiters .
Mark.
pictures can be viewed at
Mark .L.W. is offline
post #8 of 42 (permalink) Old Jan 16th, 08, 09:19 PM
Banned
can you post pics.
The peices of the broken piston will go up through the intake to the other cylinders.
CNC BLOCKS N/E is offline
post #9 of 42 (permalink) Old Jan 16th, 08, 10:30 PM
Joe
Here is your awnser.........
Please tell me this is a joke. Why would you rev it that high? I am assuming it was in nutral since it's in your garage.
All I can say is wow.
WE NEED PICTURES!
1969 Camaro....LS1/T-56.............
In the early stages of Pro-Touring
Kokamo is offline
post #10 of 42 (permalink) Old Jan 16th, 08, 10:32 PM
My thoughts exactly. Free revving a motor like that is just asking for trouble. 7500rpm under load is allot easier on it that 6k unloaded.
buenymayor is offline
post #11 of 42 (permalink) Old Jan 17th, 08, 04:43 AM
Bet they were hyper pistons too!
pdq67
post #12 of 42 (permalink) Old Jan 17th, 08, 05:33 AM
Rico
Yesterday I ran really fast into the wall. Then my nose hurt really bad and blood started coming out. Not sure why?
Just messing with ya.
Just seems like a bad idea to wind up a motor like that..
XLexusTech is offline
post #13 of 42 (permalink) Old Jan 17th, 08, 08:12 AM
This was the reason I asked long ago, why someone would rev a 302 on the dyno to 7k , unloaded.
0 deck?, wonder what quench was. And floated valves to 7500 in the garage too?
Would it really detonate in the garage?
TC # 349
zdld17 is offline
post #14 of 42 (permalink) Old Jan 17th, 08, 09:28 AM
free reving an unloaded motor like that is REALLY bad... mine has never gone above 3500 or so without a load on it.
post #15 of 42 (permalink) Old Jan 17th, 08, 09:46 AM
Matt
I bet it make a god-awful sound.
If it happened to me, I’d need to replace the motor and the driver’s seat upholstery.
Matt M. is offline
