2.08 Intake on a 400 .030 Overbore - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 17th, 08, 11:44 AM Thread Starter
Shannon
Question 2.08 Intake on a 400 .030 Overbore
Have a small block 400 thirty over with a set of Dart Pro 1's 2.08 intake and 1.60 Exaust Anyone forsee problems on a street strip car. Compression will be 11.3.
76'fire bird Trans Am Under total resto
76' Bad Bird is offline
post #2 of 8 (permalink) Old Jan 17th, 08, 11:54 AM
Steve69SS396's Avatar
Re: 2.08 Intake on a 400 .030 Overbore
Don't quite understand your question. Are you asking if the valve size will cause a problem? Or maybe you are asking about piston to valve clearance?
Steve69SS396 is offline
post #3 of 8 (permalink) Old Jan 17th, 08, 12:00 PM Thread Starter
Shannon
Engine runs but is set up with a 1050 carb and a drag cam. Wondering about the valve size. Every thing I find puts it borderline.Just looking for clarification.Thanks for cathing that slip up.
post #4 of 8 (permalink) Old Jan 17th, 08, 12:18 PM
Still don't quite understand, but I'm running AFR 210 heads on my 355 with 2.08" valves. That valve size shouldn't be a problem in your 406.
post #5 of 8 (permalink) Old Jan 17th, 08, 03:27 PM
2.08's should be ok... but that 1050 carb and only 11.3:1 ? I see the carb as an issue.
68 Camaro~LSx ~all motor
post #6 of 8 (permalink) Old Jan 17th, 08, 03:55 PM
Harley D
HarleyD67's Avatar
Ditto on the carb issue. I can tell you for a fact that 2.08's fit a std 400 bore. I've got AFR210's on my 427. Now with Steve's combo I would have some clearance concerns.
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
HarleyD67 is offline
post #7 of 8 (permalink) Old Jan 17th, 08, 05:05 PM
They bolted right on without any clearance problem. Been doing fine for 8 years now. Here is how it performs:
My '69 Camaro running 10.47 @ 129MPH with a 1.52 sixty foot at Sacramento Raceway. 355 SBC with a 150 shot.
post #8 of 8 (permalink) Old Jan 17th, 08, 05:25 PM
Gary
That's actually a good combo. (Have made some decent power with those "Pro-Ones" also!)
On a recent build (with a "Dart" block) 406" 11:1, Pro-Topline 235's (2.080's), a "small" solid roller, and a "Victor" with a 4500 and 2.000" primaries unit cam off the dyno @ 610 HP.
Is in a "street/strip" ride now, 3600#+, and runs 10.70's @ 124 MPH. All on 93 octane!
Thanks, Gary in N.Y.
P.S. In all honesty, a 2.080" valve or larger actually hurts the overall performance on a 4.000" SB (either +.030" or +.060"). The larger valves end up experiencing flow issues with the cylinder walls. We just delivered a 383" SB with 550+ HP using some 2.020's (older Brownfields) and 93 octane also! These are all slightly "higher-end" solid-roller units, not "budget-builds"!
GOSFAST is offline
