270 comp cam /low vacuum - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 17th, 08, 05:48 PM Thread Starter
I have a 327 with assorted aftermarket performance parts that I put a comp 270ah-8/ 108 lobe pn#12-321-4, the engine runs excellent has a nice deep choppy sound , the only thing is my vacuum is about 5 at idle, I set the vavles on this right I know I dont have them too tight has anybody used this paticular cam, is this normal for the vacuum
tom55 is offline
post #2 of 4 (permalink) Old Jan 17th, 08, 05:59 PM
Re: 270 comp cam /low vacuum
What is your timing at idle?
onovakind67 is offline
post #3 of 4 (permalink) Old Jan 17th, 08, 07:05 PM Thread Starter
10 degrees advanced
tom55 is offline
post #4 of 4 (permalink) Old Jan 17th, 08, 07:42 PM
Smile Re: 270 comp cam /low vacuum
I would say your timing is low. You will want up to 36 total. (14 initial + 22 mechanical advance = 36 total) I have a 270 Ultradyne ultrastreet, and if I remember right, 14-15 in. vacuum.
Also see: https://www.camaros.net/forums/showth...initial+timing
TJS69 is offline
