383 with exhaust manifolds - Team Camaro Tech
post #1 of 12 (permalink) Old Jan 23rd, 08, 09:01 PM Thread Starter
patrick
i will be putting a 383 in my 67 and i want to run exhaust manifolds . my question is will manifolds damage my engine
shox987 is offline
post #2 of 12 (permalink) Old Jan 23rd, 08, 09:54 PM
Paul
Re: 383 with exhaust manifolds
Got to believe if exhaust manifolds would damage an engine the car makers would have stopped using them many years ago. Exhaust manifolds are not as efficient as headers and that is why most non original car owners use headers.
1962vette is offline
post #3 of 12 (permalink) Old Jan 23rd, 08, 10:47 PM
383's came stock with cast iron manifolds.
onovakind67 is offline
post #4 of 12 (permalink) Old Jan 24th, 08, 05:53 AM
Smile Re: 383 with exhaust manifolds
Ford 383's;
MOPAR 383's; and finally
GM 383's.
pdq67
post #5 of 12 (permalink) Old Jan 24th, 08, 05:57 AM
Kyle
um a stock 383? I don't believe chevy ever made a 383.. but to answer the question I believe your hp will drop by maybe 5 - 10% by using manifolds (just a rough estimate) but no damage will occur.
1969 Z/28 CLONE 350
4 SPD MUNCIE,
4 WHEEL DISK BRAKES,
4:11 POSI
BLUE W/WHITE STRIPES
GreyShadows is offline
post #6 of 12 (permalink) Old Jan 24th, 08, 06:01 AM
Tim
77wolf10.85's Avatar
Manifolds are quieter too.
Old ones that have warped can be a PITA to bolt up. Not all the bolts will start. Just put a couple bolts in and start it up for a couple minutes, as it warms up and expands you can get the other bolts in. Then shut it off and put the gaskets and tighten it down. There is also a tool that un-distorts manifolds but the heat trick is easier.
Tim Smith
77wolf10.85 is offline
post #7 of 12 (permalink) Old Jan 24th, 08, 08:56 AM
AJ
G.M. made a replacement 383 for trucks, which would replace the 350 if they went out during warranty...
I'm betting he means mopar 383's came stock with manifolds....
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #8 of 12 (permalink) Old Jan 24th, 08, 11:16 AM
erik
GM does not replace any 350 with a 383 EVER, #1 reason is money and #2 because that particular 383 crate motor does not meat the EPA requirements for the vehicle. That is why it states to install in pre 78 vehicle ONLY. Sorry to point it out but you are wrong!
tumper is offline
post #9 of 12 (permalink) Old Jan 24th, 08, 11:56 AM
This is not apples to apples comparison on cast iron headers on these two motors. The 383 had a much better performace manifold. They took a shot upwards before going into pipes, pretty much like the factory race wedge motor.
Didn't mean to hijack the post.
TC # 349
zdld17 is offline
post #10 of 12 (permalink) Old Jan 24th, 08, 06:17 PM Thread Starter
patrick
thanks i will use manifolds
shox987 is offline
post #11 of 12 (permalink) Old Jan 25th, 08, 06:56 AM
LOL!!! I don't think anybody got it!!
Think about this for a second guys. When the engine that you built your 383 out of came from the factory, did it have manifolds on it?
"This is not a cheerocracy...I make the cheercisions around here"
travis is offline
post #12 of 12 (permalink) Old Jan 25th, 08, 08:15 AM
Even the factory 383's came stock with cast iron manifolds. Mine also came with 6.358" connecting rods.
