750 double pumper vs 770 street avenger - Team Camaro Tech
post #1 of 13 (permalink) Old Feb 2nd, 08, 02:09 PM Thread Starter
After having my 750 rebuilt and tweaked several times, I'm read to scrap it and get a new one. I've narrowed it down to a Holly 750 double pumper vs a 770 Street Avenger. Which would recommend?
68fan is offline
post #2 of 13 (permalink) Old Feb 2nd, 08, 03:01 PM
Ed
BigBlock1969RS's Avatar
Re: 750 double pumper vs 770 street avenger
Really depends on what car it is going on. If it is going to be used on the street at all then go with the Street Avenger with Vacuum Secondaries it can't be beat. If it is a track only car then the Double Pumper makes sense then.
Don't underestimate the value of vacuum secondaries for street use.
Ed
BigBlock1969RS is offline
post #3 of 13 (permalink) Old Feb 2nd, 08, 06:32 PM
jason
is your car a auto or a stick?
68z28sd is offline
post #4 of 13 (permalink) Old Feb 2nd, 08, 08:23 PM
Wes
Very vew with DP's wish they had a vacuum secondary carb, myself included.
Straight-line-69 is offline
post #5 of 13 (permalink) Old Feb 3rd, 08, 01:27 AM Thread Starter
My car is automatic (3 speed) with 3.08 rear gears. I also wonder about to 870 street avanger.
68fan is offline
post #6 of 13 (permalink) Old Feb 3rd, 08, 10:06 AM
Ed
Here is a link to Holley's PDF on Carb selection:
http://www.holley.com/data/TechServi...Carburetor.pdf
Quick Reference guide:
http://www.holley.com/data/TechServi...0Reference.pdf
Also here is a direct link to a Holley's online tool for Carb selection (kind of cool)
http://www.holley.com/applications/C...bSelection.asp
It is very hard to beat the drive ability on the street of a Vacuum Secondary carb with a vacuum advance distributor. Now on the track is a different story, but on the street we don't spend nearly as much time at WOT as we do at part throttle. WOT is where a double pumper really starts to shine over vacuum secondaries, so it really all depends on what you are doing.
Ed
post #7 of 13 (permalink) Old Feb 3rd, 08, 04:12 PM
Vince
I've ran both the 750 DP and 770 Avenger on my 454/525HP 5 spd 3:90 Chevelle, and I decided to keep the Avenger...it gives nothing up to the DP.
VINCE
69 CHEVELLE SS
502 EFI/[224/228 HR]/T56/3.90
*1.8/11.59/124.34*
SIDEWAYS is offline
post #8 of 13 (permalink) Old Feb 3rd, 08, 07:32 PM Thread Starter
I'm leaning toward the 770 street avanger.
68fan is offline
post #9 of 13 (permalink) Old Feb 3rd, 08, 08:42 PM
Kevin
Have you even mentioned engine size?
Learning & Relearning about the cars I grew up with.
69' - Built 350, 750 Holley, Elgin E920P Cam, 283 PP Heads, Long Comp Headers, MSD, TKO-600, 12 Bolt Posi 3.73, Hotchkis Rear, Eibach Front w/Hotchkis Sway, SPC UCAs, 3rd Gen PS, AR TTII's. Still working on it.
dbx1969 is offline
post #10 of 13 (permalink) Old Feb 3rd, 08, 10:04 PM
Harley D
HarleyD67's Avatar
I was just thinking the same thing. Although it wouldn't change my suggestion on going with the 770 vac. sec. But it would influence size. I'm assuming big block. But if it's a small block then go 670.
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
HarleyD67 is offline
post #11 of 13 (permalink) Old Feb 4th, 08, 09:31 PM Thread Starter
396 350hp
68fan is offline
post #12 of 13 (permalink) Old Feb 4th, 08, 09:45 PM
6D9
Ron
Holley 3310 or 770SA
69 Camaro
491/AFR 315'S/Straub hyd roller
TH400/GV OD
9" 3.50
6D9 is offline
post #13 of 13 (permalink) Old Feb 4th, 08, 10:08 PM Thread Starter
I'm Going With The 770 Street Avenger
68fan is offline
