106 lsa OK with power brakes? - Team Camaro Tech
post #1 of 2 (permalink) Old Feb 5th, 08, 07:26 PM Thread Starter
Derek
I guess this could go in the brake and suspension forum, but figured I would try here first. Getting close to doing the brakes on my project, was planning on going with a manual conversion until I heard another local camaro today, his cam sounded more choppy than mine and I know he is running power brakes. I am running a crane saturday night special cam with 106 lsa and it has a nice chop to it and seems to run pretty good. Would power brakes work. Should I do a vacuum test to see, if so, how much vacuum do I need for power brakes Engine is a 350 with flat tops and old set of 291s.
dtm1968 is offline
post #2 of 2 (permalink) Old Feb 5th, 08, 07:52 PM
Dan
Re: 106 lsa OK with power brakes?
7 or 8" dual diaphram brake booster and a vac. can with a check valve, you should be ok; hard to say for sure without all the specs, but you should be ok with the right brake booster combo.
62 Corvette (Stock Restoration)
68 RS/SS Camaro, LS7/T56
68 RS Convertible project LS3/480/4L70
2006 Corvette Z06
2011 Corvette GS Convertible
68sixspeed is offline
