priming oil pump - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 6th, 08, 06:58 PM Thread Starter
Steven
stamatisg1977's Avatar
priming oil pump
hey guys i was wondering....from my last posts about possible engine bearing failure, i went to prime the oil system to run a compression check and noticed that the drivers side rocker assembly flowed oil and the passenger side took a couple of minutes before i seen any oil come up but it was no way neer the amount that flowed through the drivers side. my question is....could that also indicate main/rod bearing damage?im thinking since the clearences are greater that the oil just escapes throught the bearings instead of making its usual path
thanks for listening to this long post
-Steven
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is online now
post #2 of 4 (permalink) Old Feb 6th, 08, 07:16 PM
Tim
77wolf10.85's Avatar
Re: priming oil pump
You have to slowly roll the engine for flow to get through the lifter galleries. The lifters impede the flow. One of the back ones on your right bank was at the stroke spot that blocks most of the flow past it. It can take several minutes or longer lubing and rolling by hand to get flow at all pushrods.
Tim Smith
77wolf10.85 is offline
post #3 of 4 (permalink) Old Feb 6th, 08, 07:20 PM Thread Starter
Steven
well that clears it up thanks wolf!! it seems you were with me throughout this mess that im in passing on your knowledge no matter how insane my questions or problems were
thanks man
-Steven
Tremec TKO 600
post #4 of 4 (permalink) Old Feb 6th, 08, 07:38 PM
Tim
Anytime Steven. Good luck.
Tim Smith
