Back of engine bellhousing bolt number ? - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 7th, 08, 08:24 PM Thread Starter
Billy
Question Back of engine bellhousing bolt number ?
on the back of some 69 year model engines,where the tranny bolts to the back of the block,why is there only 6 bolt holes vs. 7 on others.
are the engines with 7 bolt holes ,4 bolt main motors?and the ones with 6 bolt holes 2 bolt mains?
hope this makes sense........
member since 2002
Billy d. is offline
post #2 of 7 (permalink) Old Feb 7th, 08, 09:02 PM
Re: Back of engine bellhousing bolt number ?
I have no idea why some blocks are drilled for 6 bolts and some for 7, but it definitely doesn't have anything to do with the block having 2 or 4 bolt mains.
buenymayor is offline
post #3 of 7 (permalink) Old Feb 7th, 08, 09:29 PM Thread Starter
Billy
every 4 bolt main ive seen has 7 bolt holes.all two mains have 6 that ive seen.
just coincidence............maybe.
just wondering why the coincidence though.thanks
member since 2002
Billy d. is offline
post #4 of 7 (permalink) Old Feb 7th, 08, 09:33 PM
My 68 327 block, casting number 3914678, has 7 bolt holes. It is absolutely a 2 bolt main block
post #5 of 7 (permalink) Old Feb 7th, 08, 09:50 PM Thread Starter
Billy
thanks Jim you put the main capps ? to rest.
But it still leaves the ? as to why sometimes the top seventh hole is not tapped on some blocks and tapped on others.
member since 2002
Billy d. is offline
post #6 of 7 (permalink) Old Feb 8th, 08, 06:53 AM
i thought the top bellhousing bolt was only used on trucks and other large vehicles. most th350's and 400's ive seen dont have the top bolt hole but ive seen a few truck th400's that had the top bolt hole, hope that helps.
BLADE4444 is offline
post #7 of 7 (permalink) Old Feb 8th, 08, 09:10 AM
My 1970 CE block has 7 but in many stock bellhousings like the 621, don't have the hole for this. My Lakewood did.
TC # 349
zdld17 is offline
