Valve ticking? - Team Camaro Tech
post #1 of 39 (permalink) Old Feb 8th, 08, 11:59 AM Thread Starter
Kevin
Valve ticking?
Just took my 69' out for a drive (great weather here today) and I can hear a very audible ticking sound. I'm pretty sure I heard it when I drove it 2wks ago, but didn't investigate. At one point, I thought I had the turn signal on, as it sounds just like it, but of course, increases/decreases with rpms. I popped the hood with it idling and it sounds like it's ticking at the back of the valve cover...like above #5 or #7. It's a built 350 with roller rockers. If/when I take the cover off, what exactly should I be looking for? And does it sound like it might be an easy fix/adjustment? I'm an idiot when it comes to engines, so be nice
Learning & Relearning about the cars I grew up with.
69' - Built 350, 750 Holley, Elgin E920P Cam, 283 PP Heads, Long Comp Headers, MSD, TKO-600, 12 Bolt Posi 3.73, Hotchkis Rear, Eibach Front w/Hotchkis Sway, SPC UCAs, 3rd Gen PS, AR TTII's. Still working on it.
dbx1969 is offline
post #2 of 39 (permalink) Old Feb 8th, 08, 12:16 PM
Charlie
Re: Valve ticking?
I had that same exact issue and it turned out to be a leaking header gasket.
67CamaroRS/SS is offline
post #3 of 39 (permalink) Old Feb 8th, 08, 12:19 PM Thread Starter
Kevin
Re: Valve ticking?
I checked the bolts for tightness 2wks ago when I heard it, as it was a fainter sound. It's louder now...but my hearing kinda sucks too.
EDIT: Hmm...I was able to tighten the two rear bolts down a bit...and it seemed to lessen the sound. The back one is kinda tough to reach. I think I'll support the collector just a bit and try to tighten more after it cools off a tad. You might have guessed the problem Charlie.
dbx1969 is offline
post #4 of 39 (permalink) Old Feb 8th, 08, 12:50 PM
Banned
Ron
Badbird's Avatar
Re: Valve ticking?
Typically, old people drive around with their turn signal on but they wouldn't be able to hear any ticking noise anyways so at least you can still hear good!.....No, but seriously, hopefully it's just a loose valve adjustment and not a bad rocker arm.....Grasp the pushrod with your fingers and see if you can move it up and down, if so, then you'll need to readjust the valve.
Also, look for any black carbon trail around the header flange, which would indicate a leakage.
Badbird is offline
post #5 of 39 (permalink) Old Feb 8th, 08, 12:52 PM
Nick
Rarerat's Avatar
Re: Valve ticking?
I used to have the same problem with my old Blue 69. It had headers on it and for some reason would allways burn the header gasket out on # 8 cyclinder. I finally replaced the cheep gaskets with a set of percys aluminum gaskets and never had aproblem again.
Rarerat is offline
post #6 of 39 (permalink) Old Feb 8th, 08, 01:03 PM Thread Starter
Kevin
Re: Valve ticking?
LOL. I'll try that Ron. Can't see any obvious black marking, but it's hard to see so far back. It's a beautiful day here, but I may not have time to check the valve itself until tomorrow.
I will keep this in mind.
dbx1969 is offline
post #7 of 39 (permalink) Old Feb 8th, 08, 01:47 PM
Re: Valve ticking?
That's what I was thinking also kevin. Mine was doing the same thing on the P/S, when I took them loose the center gasket was blown out. I replaced them on both sides while I was at it, just used the cheap felpro gaskets . Still have a slight tapping in either the #4 or #6 cylinder.
Glacier Blue/Dover White 69 SB SS Restoclone.
99 Trans Am...my toy
Old Man is offline
post #8 of 39 (permalink) Old Feb 8th, 08, 04:10 PM Thread Starter
Kevin
Re: Valve ticking?
Thanks Mark. I had to go p/u my oldest from school for the wknd, and I just got back. I will just take the headers loose on that side tomorrow and see what the gasket looks like....and go from there. I tightened up the header and thought for a moment it sounded better....but I'm not really sure and I don't like hearing anything that doesn't sound normal
dbx1969 is offline
post #9 of 39 (permalink) Old Feb 8th, 08, 04:58 PM
Re: Valve ticking?
Not to hijack this thread too much but I have the same problem. But, mine is not a header gasket leak. I recently installed new headers and aluminum gaskets and am sure they are not leaking. I have had a lifter/valve noise mostly on the passenger side for a while now. Since I have no idea what cam is in my 402 (396), I was asuuming that it is suppsoed to sound that way. The only thing I know is it has roller tipped rockers. While driving the car last Sunday I noticed that the performance was dropping off and it got to the point that it would not idle. Yesterday, I started it up again and it runs a little rough and will not stay running below 2000 rpms. When I get the time I am going to pull off the valve cover, turn the engine over and check the rocker movement to see if there is a valvetrain problem.
Any other suggestions are welcome.
Dave, member number 7704
2000 Dodge Viper GTS
drdave69 is offline
post #10 of 39 (permalink) Old Feb 9th, 08, 06:37 AM
Re: Valve ticking?
Originally Posted by drdave69 View Post
Not to hijack this thread too much but I have the same problem. But, mine is not a header gasket leak......... While driving the car last Sunday I noticed that the performance was dropping off and it got to the point that it would not idle.........
This is probably worth starting a new thread, just so you get better info. But from your description, the very first thing I would do is a compression test of all 8 cylinders. If you have a performance loss, then something ain't right. A compression test will tell you which cylinder(s) to look at more closely. Could be loose/worn valvetrain component, worn cam lobe, bent push rod, stuck lifter, head gasket leak, etc, etc..............
Of course, check the basic things too, like plugs, wires, cap and rotor. Also, look for vacuum leak. Maybe a vacuum hose fell off???
Dave F. in Rhode Island
Chevy-SS is offline
post #11 of 39 (permalink) Old Feb 9th, 08, 07:35 AM
Charlie
Re: Valve ticking?
I had a hell of a time tightening #8 cylinder bolts. I had to use swivels, extensions, etc. I have since used thread lock on them. I haven't had any further issues. I have ARP bolts that I may use that are drilled so I can use safety wire to keep them from backing out along with the thread lock. Another thing Kevin, I had a cam go out on me. I had two lobes wipe and it made alomost the same sound. When it started again I was pissed, but it ended up just being the header gasket. If you are getting the sound to change by tightening the header/manifold bolts, then I would lean toward that being the problem area.
post #12 of 39 (permalink) Old Feb 9th, 08, 08:10 AM Thread Starter
Kevin
Re: Valve ticking?
When it warms up here in a little while, I'm going to investigate further. Gosh, I hope it's just the gasket. If it's a loose valve...I'll be back on here asking how to tighten it, unless it's real obvious. I've never made it a secret that I know zero about engines. The closest thing for me working on an engine was replacing the valve cover gaskets on my 79' Z...about 25yrs ago .
dbx1969 is offline
post #13 of 39 (permalink) Old Feb 9th, 08, 11:01 AM Thread Starter
Kevin
Re: Valve ticking?
OK, here's a pic of the rockers. As you can see, the 2nd from the end on the right is down, while the rest are up (actually, the very 1st one is ever so slightly down). What does this mean...and how can I fix it? Is it likely that this one rocker is making the ticking sound I'm hearing?
dbx1969 is offline
post #14 of 39 (permalink) Old Feb 9th, 08, 12:19 PM
Re: Valve ticking?
In no way does that indicate a bad (or noisy) lifter. It just means that particular cam lobe is actuating the valve. You would always see a few like that. Rotate the engine slowly by hand and you'll see they all move (eventually). Two crankshaft rotations will rotate the cam once - each valve will go up and down one time during that process.
I would start by adjusting the lifters, to see if one is slightly loose. I like to set mine (assuming hydraulics) at zero lash plus 1/4 turn.
Chevy-SS is offline
post #15 of 39 (permalink) Old Feb 9th, 08, 12:27 PM Thread Starter
Kevin
Re: Valve ticking?
Thanks Dave. It's comforting to know that the position is apparently normal. But...I have no idea how to adjust them or what zero lash even means.
dbx1969 is offline
