Re: Raising the engine...higher mounts
Sounds like you have the wrong pan to me .
Are you using an after market or stock pan?
The big block frame mounts would not work for you anyway as they will
lower the motor even more.
Notching the pan? I dont know..... Think you may be asking for leaks all depending on how much you have to notch it I guess.
There are spacers available that go between the motor and the mounts , If memory serves me correctly they are around 1/4" thick , don't know if that will give you enough or not.
How much more clearence do you need.
Thinking out loud is all.
Russ
1969 RS conv,hugger orange,396 4 speed,373 12 bolt posi.
