LT1 Timimg - Team Camaro Tech
post #1 of 2 (permalink) Old Feb 9th, 08, 07:04 AM Thread Starter
LT1 Timimg
Can this engine be timed. Why is there is no key way on crank. The book said to put at TDC # 1 with arrow up on crankshaft balancer. Where is the timing mark ?
Sparkey is offline
post #2 of 2 (permalink) Old Feb 9th, 08, 08:57 AM
Jody
camcojb's Avatar
Re: LT1 Timimg
the optispark only goes on one way, so if the timing chain is installed correctly you're good to go. The timing is controlled through the computer, so you'd need a tuning program to change it. The balancer doesn't matter how it's installed as regards to timing, but I think they give those general guidelines for engine balance more than anything.
Jody
camcojb is offline
