396 375 L78 Casting numbers - Team Camaro Tech
post #1 of 9 (permalink) Old Feb 9th, 08, 04:21 PM Thread Starter
Lee
mrmuncie's Avatar
Hi! I have a 272 L78 block that I'm rebuilding. It's been decked off so their is no date stamp on the pad. I'm looking for a set of matching 840 heads that would be right for the block. What would be a good date for heads to match block? Thanks!
Lee (in Louisville, Ky)
Second owner 69 SS Camaro 350 A/C Stick
I specialize in Muncie 4 speeds. Rebuilding tranys for 20 years with over 50 Muncies to select from. If your looking for a certian date code I should be able to help.
mrmuncie is offline
post #2 of 9 (permalink) Old Feb 9th, 08, 09:36 PM
Re: 396 375 L78 Casting numbers
What is the casting date of the block? It should be cast into the passenger side of it?
buenymayor is offline
post #3 of 9 (permalink) Old Feb 10th, 08, 06:42 AM Thread Starter
Lee
mrmuncie's Avatar
It's 12 20 68 Thanks
mrmuncie is offline
post #4 of 9 (permalink) Old Feb 10th, 08, 09:50 AM
Find a set of 840 heads that are close to 12 20 68 (Dec. 20, 1968). I'd think you'd want a set dated within a week of of the 20th. You'll need a 163 intake, too. The date is cast into the bottom of those, so it won't be seen once installed. Beware that GM was still making the 163 intake a few years ago (maybe they still are). The newer ones look differently than the original ones from 69.
post #5 of 9 (permalink) Old Feb 10th, 08, 04:12 PM Thread Starter
Lee
mrmuncie's Avatar
Thanks for the info. Lee
mrmuncie is offline
post #6 of 9 (permalink) Old Feb 10th, 08, 04:48 PM
I see you are in Louisville. I'll be there later this week one day for the Farm Machinery Show. Not looking forward to the crowd, though. Take care, Lee.
post #7 of 9 (permalink) Old Feb 10th, 08, 05:13 PM
Tony
Is it 2 bolt or 4 bolt main?
Tony W.
67 rs/ss L48 org.37k w/headrest seats
67 rs/ss L35 org.78k w/smog
67 rs/ss L78 O-O sherwood green -L201C
68 rs/ss L89 convertible
67RS/SS396 is offline
post #8 of 9 (permalink) Old Feb 10th, 08, 06:54 PM Thread Starter
Lee
mrmuncie's Avatar
It's a 4 bolt main. I'm also looking for a 69 70 8 inch timing chain cover. It should have dowel pin holes with AOR on the timming tab.
mrmuncie is offline
post #9 of 9 (permalink) Old Feb 10th, 08, 06:56 PM Thread Starter
Lee
mrmuncie's Avatar
Sounds good Tony. I know that the Louisville Swap Meet is comming up. Hey I'm also looking for a 69 70 timming cover for 8 inch damper. it should have AOR on the timming tab.
Lee
mrmuncie is offline
