Water Transfer Tube HELP ?????????? - Team Camaro Tech
post #1 of 2 (permalink) Old Feb 11th, 08, 12:44 PM Thread Starter
I just finished putting in new head gaskets in my sons 1997 Z28. I am left with the water transfer tube on left front of engine. Its bolts in back of the heads. WHERE DOES THE OTHER END GO ??????????
Sparkey is offline
post #2 of 2 (permalink) Old Feb 12th, 08, 11:26 PM
Re: Water Transfer Tube HELP ??????????
It goes from the steam tube to the throttle body and then from the throttle body to (I believe) a tee in the upper radiator hose.
For warm weather use, the steam hose can be routed around the throttle body to make the intake a bit cooler.
67 Camaro, 96 LT1, 4L60E
red67camaro is offline
