Crank Pulley - Bolt torque and tighten sequence - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 11th, 08, 07:23 PM Thread Starter
I just replaced my crank pully with a 3 groove alum pully. Not sure if the center bolt is tighted to 55 to 60 torque first and then the 3 pulley bolts (torque ?) or vice versa.
Also, i will be added brackets for aftermarket ac and could use a quick torque tip for the intake front bolts and exhaust bolts. I think the exh is 25lbs.
This is a crate 350 small block motor. Nothing special.
Thanks in advance for any help. In over my head and just scrambling trying to keep this major project (ac and interior redo) going.
68camrs
68camrs is offline
post #2 of 3 (permalink) Old Feb 11th, 08, 07:31 PM
Tim
77wolf10.85's Avatar
Re: Crank Pulley - Bolt torque and tighten sequence
Does the crank bolt have a big washer that is going to seat against the forward face of the pulley? If so then you need the 3 small screws run up snug before you do the crank bolt.
Tim Smith
77wolf10.85 is offline
post #3 of 3 (permalink) Old Feb 11th, 08, 07:36 PM Thread Starter
Yes, it has the big flat washer. Thank you. Do you have the torque on those?
68camrs is offline
