1965-66 396 engine identification help!!! - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 13th, 08, 05:05 PM Thread Starter
I recenlty aquired a 396 casting code 3855961 which tells me it is a 65-66. The problem I am having is the stamp pad numbers, specifically the suffix code. The numbers read as follows T122IIVR I could be mistaking an I for a 1 but I can't find any VR suffix codes. I do find IV which would be correct for the 1965 but where is this R coming from??? I have researched the web for days and have the chevrolet book of numbers with no success! Save me from my misery!!!!
Thanks for any help!
Randy
5636randy is offline
post #2 of 7 (permalink) Old Feb 13th, 08, 05:52 PM
geneo
Re: 1965-66 396 engine identification help!!!
IV = 65 66 Impala (if I remember correctly) R = Rochester carb
gene_sc is offline
post #3 of 7 (permalink) Old Feb 13th, 08, 06:00 PM
All I can find is :
IV 1966 396 325 Chevrolet
IV 1968 396 325 Chevrolet
IV 1967 396 325 Chevrolet AR
IV 1965 396 325 Chevrolet
TJS69 is offline
post #4 of 7 (permalink) Old Feb 13th, 08, 06:21 PM
geneo
http://www.chevymania.com/partsid/suffix.cfm?block=Big
check here select IVR code
IVR 66 396 Impala 325 L-35 TH-400 4-Brl Rochester
gene_sc is offline
post #5 of 7 (permalink) Old Feb 13th, 08, 10:55 PM
james
hello saw your inquiry and i did a little research and found some info for you on the 3855961 number, it could be 1965-1966 2or 4 bolt block 396 or it could be a 427 1966 2bolt block hopefully that might help a little bit more thnx
goldcarman is offline
post #6 of 7 (permalink) Old Feb 14th, 08, 05:53 AM Thread Starter
Thanks for all the input guys! I was hoping it to be date correct for my 1965 Impala SS, maybe should find a 66?
Thanks,
Randy
post #7 of 7 (permalink) Old Feb 14th, 08, 09:11 AM
geneo
Thanks,
Randy
I think I still have a 396, IVR code, I'll look at the casting date and see if its a 65 block.
gene_sc is offline
