wobbling power steering pulley - Team Camaro Tech
post #1 of 8 (permalink) Old Feb 13th, 08, 07:49 PM Thread Starter
Jeff
guys,
ive got a brand new zoops power steering pulley and a brand new power steering pump. both are the keyed kind. well, i put the pulley on and tighten the nut down and viola... the pulley wobbles as i spin it around by hand.
the guy at kragen told me this is normal. come on man... if it wobbles at hand-turning speed, whats it gonna do at 7000 rpm?
this isnt normal, right?
is the pulley bent? any way to check it? seems flat when i put it on a table.
is it installed crooked?????????
any ideas?
thanks
jeff
1967 SS 396, M20.
now a 10.4:1 540, AFR 315 heads, UDHarold SR Cam with a Tremec TKO
jks67SS396 is offline
post #2 of 8 (permalink) Old Feb 13th, 08, 08:47 PM
Re: wobbling power steering pulley
I had the same exact thing happen. with the same parts. I back the nut off a bit, it runs true, tighten it up, and it goes to wobblen. I was told the same thing. The only way I could fix what I had was to get a locking nut. I tighten it snug with a 1/4 turn more. Its been going 6500 to 7000 for almost a year now. Straight as a arrow.
Travis1 is offline
post #3 of 8 (permalink) Old Feb 13th, 08, 08:49 PM
Smile Re: wobbling power steering pulley
put a long shaft into the pulley and use a square to see if the hub is straight on the pulley or not. (90 degrees - perpindicular...)
TJS69 is offline
post #4 of 8 (permalink) Old Feb 13th, 08, 11:29 PM Thread Starter
Jeff
ill have to go get a shaft that fits the pulley.
but as far as the locking nut idea, i dont get it. no matter where i put the pulley on the shaft (and how tight the nut) it wobbles.
i think the fact that it lays flat on the table doesnt mean that it wobbles... think that the hub has to be concentric to the pulley and if not, then it wobbles.
i think something musta happened to this pulley at some point. i just opened it, but ihave had it for almost 8 months.
1967 SS 396, M20.
post #5 of 8 (permalink) Old Feb 14th, 08, 05:17 AM
The PS shaft is tapered. Remove the key and install the pulley and tighten, check for straightness.
Key may be too thick/high.
Everett#2390 is online now
post #6 of 8 (permalink) Old Feb 14th, 08, 07:18 AM Thread Starter
Jeff
ok, i pulled the key and it still wobbles. i think the pulley is bent. sitting in a box in my trunk for 8 months, it got bent???
1967 SS 396, M20.
post #7 of 8 (permalink) Old Feb 14th, 08, 07:21 AM
I had the same problem with a new pully I was told they were not mach well. I used a original and painted it problem solved.
blue ss is offline
post #8 of 8 (permalink) Old Feb 14th, 08, 07:35 AM Thread Starter
Jeff
might be what i need to do. im gonna take it to work and at lunch, see if i cant go look at another pump just to make sure its not the pump shaft...
thanks guys
1967 SS 396, M20.
