Comp cam lobes wiped?? - Team Camaro Tech
post #1 of 24 (permalink) Old Mar 18th, 08, 02:20 PM Thread Starter
Kevin
KevinW's Avatar
My neighbor (Steve) came over last night to return a distrib he borrowed to diagnose a rough running 396 and told me this story. After dropping a valve on the 396 (factory butternut yellow, 69 SS El C) he decided to rebuild the engine. His engine builder special ordered a comp cams LS6 hyd cam. They waited over 2-3 weeks for it. Pre-lubed the engine correctly (he is a very experienced former Drag racer) and started it up. Ran fine for 15 mins @ 2000 rpm, then started stumbling. After much trial and error, pulled the engine to find most of the lobes in the oil pan. He thinks they missed a heat treating step. Engine is back to the builder for cleaning the shavings out and the cam went back to Comp.
So what do you think happened?
Kevin
KevinW is offline
post #2 of 24 (permalink) Old Mar 18th, 08, 03:14 PM
Greg
Re: Comp cam lobes wiped??
Ouch! I wonder I they had a bad run of blanks.
This why I went roller and wont go back.
68 383, TH-350, 3.55 Eaton Posi, Holley SA 770, RPM Air Gap, World Sportsman II, ISKY Roller Cam
emperor91108 is offline
post #3 of 24 (permalink) Old Mar 18th, 08, 04:13 PM
Alan
There was a thread a couple of months ago about Comp Cams and this issue of cam life being measured in minutes as opposed to years. Seems you are not the only one experiencing this phenomina.
alan
alanrw is offline
post #4 of 24 (permalink) Old Mar 18th, 08, 04:18 PM
Harry
dawg's Avatar
thats why ill never use another comp cam again.
same thing happened to me years ago and the shop i took the cam to said the heat treating wasnt the best.
once in awhile they get a few that did the same.
434 stroker
US Navy retired
dawg is offline
post #5 of 24 (permalink) Old Mar 18th, 08, 05:55 PM
had a customer with a 350 he put together that had heavy surface rust and he wiped out several lobes , he said the lifters were hard to get in so he used a dead blow hammer to bump em down , he figured they would loosen up when he reved it up a couple times, he doesn't want to build any more engines. his cam was a Reed. poor cam just didn't have a chance.
prostock is offline
post #6 of 24 (permalink) Old Mar 18th, 08, 06:18 PM
Patrick
I've heard this too many times. This is why I will never buy or refer anyone to get a Comp Cam. Too much neg feedback about Comp Cam. Too risky for me.
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
post #7 of 24 (permalink) Old Mar 18th, 08, 06:43 PM
Harvard
Sorry to hear, but mine went without a hitch. XS282S
1968 Z28 British Green, all original except CE 302 engine. Have original owners booklet and protect-o-plate.
68zproject is offline
post #8 of 24 (permalink) Old Mar 18th, 08, 07:42 PM
Tim
77wolf10.85's Avatar
LMAO
My new custom SR is a Comp, again. And it is a work of art. Again.
Ain't skeered.
Tim Smith
77wolf10.85 is offline
post #9 of 24 (permalink) Old Mar 18th, 08, 07:47 PM
Robert
My CC 280H is great. Old school and perhaps old stock, I don't know.
One bad apple don't spoil the whole bunch.
Robert
TC member #18
rojo is offline
post #10 of 24 (permalink) Old Mar 18th, 08, 11:12 PM
67 Camaros Rock
Joe Harrison's Avatar
From what I heard there are only a few places that cast the blanks for the CAMS that all manufactures buy from, they then put their grind on the blanks they buy. I know that Schneider Cams in San Diego bought them this way and I believe Crower did/does also?
Joe
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline
post #11 of 24 (permalink) Old Mar 19th, 08, 09:10 AM
Wait, what is a LS6 cam for a 396? I went with on of Harold's billets after loosing a cast roller from Comp. Seems they have problems here too.
TC # 349
zdld17 is offline
post #12 of 24 (permalink) Old Mar 19th, 08, 09:54 AM Thread Starter
Kevin
KevinW's Avatar
I'm not sure why he went with a 454 custom grind versus an off the shelf. I thought it was strange too.
Kevin
KevinW is offline
post #13 of 24 (permalink) Old Mar 19th, 08, 12:07 PM
Gary
I just dropped my motor back in that was out due to wiped cam (Lunati). A little battle between the cam and the modern low-zinc or no-zinc oils. (guess who lost!!) I went with a comp roller...can't think of the name right now, but it's one that is supposed to give you the lopey idle, while retaining low end torque.
I swear I am not pulling the motor again.....if the cam goes, the car goes!
Unreal is offline
post #14 of 24 (permalink) Old Mar 19th, 08, 06:18 PM
Harvard
I got some of the zinc additive that was on a thread here a while back. So far so good. I hope it's not snake oil.
post #15 of 24 (permalink) Old Mar 19th, 08, 06:57 PM
oh......that's just lovely!!!
I have a 290HR on the garage shelf waiting it's turn!
dubs68camaro is offline
