converting Holley vac secondary fuel bowl to DP????? - Team Camaro Tech
post #1 of 1 (permalink) Old Mar 18th, 08, 10:53 PM Thread Starter
I was bored and out in the garage looking at some of my Holley stuff....mainly a couple of 3310 secondary bowls. Why couldn't these be converted to a DP rear bowl?? They already have the hole on the gasket side that could be drilled the rest of the way through to feed the squirter. A guy could also drill and install a check ball or valve. Aside from tapping some threads for the pump housing, it sure looks like it would work. I know it's easier to just buy this right bowls, but It would give me something to do and allow me to use a now un-usable part. Thanks!
dubs68camaro is offline
