starting issues - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 19th, 08, 09:54 AM Thread Starter
Question starting issues
I have a 1992 camaro RS 5.0 5 speed, At times I go to start it and get nothing, not even the turning of the engine. Then 5- 15 minutes later I go out it fires right up. Any ideas? thanks,
will
willyz8 is offline
post #2 of 5 (permalink) Old Mar 19th, 08, 10:05 AM
Re: starting issues
Could be bad electrical connections. Do the headlights always work? If they do check your starter positive cale and engine block ground to make sure they are in good shape and not corroded.
Chris
1968 Camaro, M-21 4 Speed, 327ci
forttusken is offline
post #3 of 5 (permalink) Old Mar 19th, 08, 10:27 AM
Vintage 68's Avatar
Re: starting issues
Is this the original key or a replacement ???
Have you tried cleaning the key ????
These cars havee a VATS system to prevent starting by a pass-key, you need the original to get it started.
Some replacement keys will cause a problem also.
The system will prevent the starter from turning once they 'lock-in' for @15min. until they reset.
Had this problem with the daughters car for a while until the dealer reset the system and coded two new keys ...
1968 Convertible
Some trucks
Vintage 68 is offline
post #4 of 5 (permalink) Old Mar 19th, 08, 10:44 AM Thread Starter
Re: starting issues
I have a extra set of keys to it and both sets did the same thing. They should be original sets due to the GM logo and casing around them.Now I did notice that on the metal shaft of the keys the raised piece surrounded by a black square are worn. Is that part of the key you are refering to that needs reset? thanks, will
willyz8 is offline
post #5 of 5 (permalink) Old Mar 19th, 08, 10:46 AM Thread Starter
Re: starting issues
yes , my lights do always work, and I did take the car to the car wash and cleaned the whole engine completely off. It did the same thing even befroe I cleaned it. Is it possible the clutch pedal ignition switch going bad?
willyz8 is offline
